My sku:scs-26uc4 just quit after years of faithful service. the lights will not come on at all. I have unplugged and replugged...nothing. any suggestions?
  • 3,320 Answers
If your TV is more than 4 years old repairs will cost as much as a new or refurbished replacement.
Here's something to try:
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Posted on Apr 24, 2015
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
I have reset the service engine soon light, no help, and unpluged the repluged the accelerator pedal harnes, nothing,
It will not help buy allways deled the check engine light untill the (problem) is repaired (Properly) Then the light will not come on any more,
Nov 09, 2012 | 2004 Nissan Quest
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
My 1991 Honda Accord 2.2 auto will not start. The speedometer quit working,the check engine light and the S light came on while driving about 90 Km's per hour, then the car stalled. I tried to restart...
the S light is on more than likely because of you speedometer or your vss "vehicle speed censor" which is connected to your transmission im having the same problem on my 91 accord lx. check the codes and let me know what the codes are and i may be able help a little more if you dont know how to check the codes I can help with that as well
Oct 14, 2011 | 1991 Honda Accord
Srs light stays on on my Honda civic
The most likely possibility is the connector for the airbag is not on securely. Check the connector first. But if the connector is connected properly then you will have to get the error codes to locate the exact problem for SRS light ON.
There is a way to pull the codes from the SRS control unit without a scan tool.
1. Turn the ignition switch OFF , and wait for ten seconds. Then connect the SCS service connector to the service check connector (2P). If you do not wait ten seconds, the SRS unit will not be completely reset and will not output DTCs.
2. Turn the ignition switch ON (II). The SRS indicator light comes on for about six seconds and goes off. Then it will indicate the DTC:
· The DTC consists of a main code and a sub-code.
· Including the most recent problem, up to three different malfunctions can be indicated.
· In case of a continuous failure, the DTC will be indicated repeatedly.
· In case of an intermittent failure, the SRS indicator light will indicate the DTC one time, and then it will stay on.
· If both a continuous and an intermittent failure occur, both DTCs will be indicated as continuous failures.
· In case the system is normal (no DTC), the SRS indicator light will stay on.
3. Read the DTC.
4. Turn the ignition switch OFF, and wait for ten seconds. Then disconnect the SCS service connector from the service check connector (2P).
The SCS Service Tool is nothing more than a jumper wire.
Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | 2000 Honda Civic
Battery was low and put in new battery,problem SRC Light stays on how can I reset the SRC light?
I'm guessing you mean the SRS light, yes. When you have a bad battery the battery voltage can drop below 10 volts. The SRS unit detects this voltage loss and set a DTC (diagnostic trouble code) for an internal SRS unit failure. You have to erase the DTC memory. You'll need an SCS service connector tool (P/N 07PAZ-0010100) You can order one from your local honda dealer. Don't worry its not more than $10. Then you'll have to find the MES 2pin connector located in the upper right hand corner of the drivers underdash fuse box. It can be gray, green or yellow in color. 1.)Turn the ignition switch off. 2.)Unplug the MES connector from the fuse box and plug your SCS special tool into the MES connector. 3.) Turn the ignition switch on. 4.) The (red) SRS light in the dash will come on for 6 seconds and then go off. Remove the SCS tool from the MES (2P) connector within 4 sec. after the SRS light went off. 5.) The SRS light comes on again. Reconnect the SCS tool to the MES (2P) connector within 4 seconds after the SRS light came on. 6.) The SRS light goes off. Remove the SCS tool from the MES (2P) connector within 4 sec. 7.) The SRS light indicates that the memory is erased by blinking twice. 8.) Turn the ignition switch off and wait ten seconds. You may have to do this procedure a few time to get the steps correct. If this sounds to complicated I'm sure your local Honda dealer would be happy to reset the light for you for no charge. Just let them know that the battery was recently replaced and you think that the SRS light came on due to low battery voltage. -Hope this helps:)
Jan 13, 2010 | 1997 Honda Civic
Srs light on
1st you need to either buy or make the "SCS Service Connector" #07PAZ-0010100 from H and A Accesories for $3.51. Use a speaker harness for an older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly. 2nd you need to find the MES (Memory Erase Signal) connector as pictured below scs_small.jpgsrs_plug_small.jpg
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug.
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
Aug 16, 2009 | 2002 Honda Civic
SHARP 37HV6U No picture until long warmup
Alas, it sounds like something could be quite wrong, or it could be as simple as needing a reset. Unplug the unit, wait a minute then replug it and see what happens.
Aug 28, 2008 | LG 42LC2D 42 in. LCD HDTV
Blinking timer light nothing works
have you tried the menu and device buttons held in together to activate the led error code feature? Let me know the error code.
Jul 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
