Question about Olevia LT42HVi 42 in. LCD Television
The screen is blue but nothing shows for tv or dvr
Cable company says it is the tv but the screen is blue. how can i trouble shoot the tv? thank you
    President:
  • Olevia Master
  • 749 Answers
If your TV comes up blue and then does not respond to any button, especially if it doesn't respond to the power off then it definitely has a bad main board.
if it responds to the power off main button, but none of the other buttons has any effect on it then it may have a bad power supply, but it is about just as likely, if not a bit more, to still have a bad main board.
You can try flipping through the inputs with the INPUT button on either the unit or the remote to see if you can get it to produce sound (when on a channel / input with signal). It's a blind operation that takes some effort, but if you get it to produce sound that's a sure indication the problem is NOT in the power supply.
Short of that you need to to open the TV and measure the outputs of the PSU to rule it out, leaving out the main board and, eventually, the T-CON if the TV has one ( I did not check if your model does as it won't help me much even if I know it).
Sorry I can't be more specific, but I doubt anyone can.
Hope this helps.
Bobby
@ coppelltvrepair.com
Posted on Apr 25, 2015
  • Olevia Master
  • 3,320 Answers
Hi Mike,
If your TV is more than 4 years old cost of repairs will probably be more than a new or refurbished replacement.
Here's something to try:
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
Posted on Apr 24, 2015
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
I'm having a truly bizarre issue with my tv! THe
First of all , your TV is good,the DVR from that company are bad. the solution will be to replace with an other brand of DVr and see if the problem still there
Sep 12, 2009 | JVC HD-61FH97 61" Television
I was in the setup screen for the Protron PD-DVR-100 and chose progressive scan for the output. Then the screen went half black and half white. The trouble shooting in the manual send to put it back to...
If your player has the red blue green video inputs on the back plug your video cable into one of them the picture will be a bit distorted but you will be able to see enough to change it back. I did this one time with mine.
Aug 13, 2009 | Protron PD-DVR100 DVD Recorder
Analogic tv hookedd to cable,power on but nothing
if your tube is not out and you tv works for dvds and/ or vcr i would call the cable company if you can not trouble shoot this.
Jun 28, 2009 | Televison & Video
Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Mar 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
No Video or Sound
Hello Mabsab:
The repairs may cost starting at $ 75.00 to $100.00 for the estimate and basic trouble shooting the final cost of the repair may be about $200 to $400.00 dllars depending on the price of the part and the labor that is charged.
Aug 17, 2008 | Mitsubishi WS-55857 55" Rear Projection...
This is an encrypted channel
Hello hbennett,
When looking at cable TV some of the channels are encoded (arranged digitally) to disallow access to the content on that channel.  This is true in the case of encrypted channels, the cable company has taken that channel and through an encrypting algorithm made that channels content inaccessible to you. The only legal way to see that channel is to pay the cable company or content provider for that service (channel). I hope this helps.
Thank you, Shuttle83
Jan 05, 2008 | iLO 2600 Television
How do i get 1080p
How did you get 720p? I have having trouble viewing anything above 480p. When using my directv HD DVR, the screen goes black when it tries to show anything above 480p. Is it the tv or the DVR?
Jan 04, 2008 | Mitsubishi WS-65905 65" Rear Projection...
Olevia LT42HVi 42 in. LCD Television Logo
79 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
