If you are using your Bialetti for the first time, carry out a few practice brews and throw the coffee out. The coffee oils seal the aluminium surface and will prevent your coffee from having a metallic taste. Don't clean your moka pot with soapy water or an abrasive sponge. Remember all those great cuppas you made that imparted their special oils onto the inside of the pot? You don't want to go tarnishing that with the taste of dishwashing liquid. Simply rinsing it with hot water and wiping it with a clean cloth after each use will suffice. Alternatively, leave it out on the drying rack for a bit so that it dries out completely.
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
