Question about Zenith Televison & Video
My Zenith TV model z37lc6d . when I turn it on I get vertical lines in a row 5. the television will not show a picture.
    Top Expert:
  • Zenith Master
  • 75,311 Answers
Video processor section circuit fault. Contact any service technician. This is not a user repairable fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 25, 2015
techman
  • 3130 Answers
SOURCE: Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Posted on Nov 11, 2006
jerryg50
  • 1689 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
daniel719
  • 240 Answers
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Posted on Jan 13, 2009
  • 700 Answers
SOURCE: Picture is squeezed down to middle with a bright green horizontal
If you can do it, then just reheat or resolder the vertical ic pin for first step. If this work then no need to change the IC. Good soldering technique is needed. Do this when unit is no power and unplugged from wall socket.
Remember nasty voltages inside, it might caught you.
Posted on May 25, 2009
  • 290 Answers
SOURCE: 27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Posted on Mar 03, 2010
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Zenith tv shuts off
There is a protection shut off, due to problems in the secondary switching power supplies and this might need attention of a qualified service technician
Jul 11, 2012 | Zenith Z37LC6D 37-inch Widescreen LCD HDTV
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
TV not turning on blinking powerlight with corresponding clicking
Zenith2.gif "Presentation" is just the name of the general model.
Is it a Z37LC6D LCD TV?
Please reply with the model number and the MFG DATE so I can assist you better.
Check the rear for the exact model and the MFG DATE on the FCC label.
Check for loose power cable to the TV.
Make sure the socket the TV plug into is not overloaded.
An overload is dangerous and the voltage drop will cause the TV power supply from turning on.
If possible plug the TV into a different //// empty outlet.
A clicking sound is a signal of a failing power supply or low line voltage from the wall socket.
Please update you post on the reply window.
Oct 16, 2009 | Televison & Video
What would cause a straight line threw tho middle of my tv monitor. I have a zenith model number z27h96r8.
If this is a straight white line you may have a vertical collapse. You need to either solder bad connections at Vertical IC or change the vertical IC
Apr 23, 2009 | Zenith Z27H96R 27" TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Dec 13, 2008 | Zenith C27A24T 27" TV
Video problem
Check the solder joints on the vertical output IC. I am not sure if that model has the PIP module, but if it does then resolder those connectors, too.
Jun 16, 2007 | Zenith B32A24Z 32" TV
Blue vertical lines - no picture
you did not mention if you have sound.but if you have sound your problem is in your video and vertical section.if no sound then you have to look into the IF section.if you are not a tech then you will have to take your set to repairman.goodluck.the tuner must not be over looked.an estimate of about $200.00 could be less.
Mar 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
