Question about NAD T742 Receiver
When I switch it on it comes on then switches straight off
  • NAD Master
  • 5,056 Answers
More than likely caused by an overload being detected. Often speaker wiring touching or faulty being the culprit. If you disconnect the speaker wires, try it again and it still shuts down, you have perhaps damaged the main amp parts. Or some kind of protection circuit is stopping it.
Posted on Apr 28, 2015
Can I change my verizon moto g to straight talk without making a new straight talk account?
yes you do not have ot give straight talk any info about yourself you do not have to buy anything other then their activation kit its 60 dollars and comes with a 45 $ card. you just need to tell them you would like to bring your moto g to straight talk you have b ought the activation kit and would like to set up a new number and when they ask for your address email and other info just say i would like to not give out any personal info. I work retail and deal with this all the time.
May 12, 2015 | Motorola Cell Phones
2003 dodge neon...driving down the road and headlights suddenly stopped working. Replaced both fuses, and headlight switch. When I wire the headlights straight to the battery they work. What could be the...
Well you have replaced the 2 obvious causes.....Fuses and light switch, I would use a cicuitry tester to see if you are getting a live feed to the switch, if live coming in then the switch is still faulty if live not coming in then wiring could be burnt out or broken!
Feb 07, 2015 | Dodge Cars & Trucks
Light delays coming on
I would suggest replacing the cord switch if possible else replace the fixture.
Jan 14, 2014 | Electrical Supplies
Door light will not come on when doors are open but will work when turned on at inside switch
check the door switch for operation.. the circiut gronds at this point..if the switch is broken or out of adjustment replace it..
Jan 21, 2013 | 2009 Chevrolet Silverado 1500
I HAVE 30 TP LINK (TL-SF1008D) SWITCHES ATTACH WITH MY SERVER .IF ANY SWITCH WILL OFF OR DEAD HOW CAN I FIND THEM THAT WHICH SWITCH HAVE PROBLEM. IS THERE ANY SOFTWERE TO GET ALL SWICTHS MAC ADDRESSES OR...
A switch should not have bad ports, its just a basic level device not much higher than a hub. Make sure you are using straight through cables to connect pc's to it. you can tell if it is a straight through most of the time by looking at the colors from left to right. (see picture) this will not be the case 99% of the time but sometimes a switch or router will come with one for connecting to other switches (which is what crossovers are made to do.
nathan_f.gifNote the colors and check to see that both cables have the same. if one is different then it is a crossover (it crosses wires so that similar devices can connect together.) Hope this helps, good luck with your switch.
May 08, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
My fan wont come on my bike but i straight wired it and it still work and the fuse is some good
THE MOST OBVIOUSE REASON FOR THE FAN NOT COMING ON IS THE LACK OF WATER IN THE SYSTEM, IGNORE THE COOLANT BOTTLE, GO STRAIGHT TO THE RADIATOR AND CHECK FOR COOLANT ASSUMING YOU DO HAVE COOLANT, YOU COULD ALSO DO 1 OTHER TEST.WHEN YOU SAY YOU STRAIGHT WIRED TE FAN, DO YOU MEAN YOU PUT A LIVE FROM THE BATTERY TO THE FAN AND IT WORKED? HAVE YOU TRIED LOCATING THE THERMAL SWITCH LOCATED ON THE RADIATOR THIS WILL HAVE 2 WIRES ON IT, IT ACTS AS A THERMOSTAT WHEN THE WATER GETS UP TO TEMP(IE THE REASON FOR WATER PRESENCE) THE SWITCH ALOWS POWER TO CROSS THROUGH TO THE FAN,, JOIN TOGETER BOTH WIRES AT THIS SWITCH WITH THE IGNITION ON IF THE FAN THEN WORKS AND YOU HAVE CHECKED THE ABOVE I WOULD SUSPECT THE SWITCH IS AT FAULT.BEFORE REPLACING TEST IT USING A MULTI METERE
Aug 30, 2010 | 2003 Suzuki GSX 1300 RZ Hayabusa
Im looking for the optinal 12 outputs on a 2005 civic's fusebo, as im trying to connect and glow gauge face and i need a 12v when parking lights are on
Hook it up straight to switch. Just strip a little wire on the ones that are already there. Or get your own toggle switch and hook it straight to fuse box or cig lighter, or radio wiring.
I would just take out the ashtray light bulb and cut the wires and use those one. Then it will come on when light come on.
Jul 05, 2009 | Honda Civic Cars & Trucks
NAD T742 Receiver Logo
113 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
