Question about NAD T742 Receiver
When i switch it on surround it powered up but then switches itself off
1995 mazda 626 power window switch troubleshoot
Use paper towels and surround the switch. With the ignition off soak down the switch with WD-40 and work the switch back and forth firmly and quickly. This will clean the switch contacts.
Sep 23, 2014 | Mazda 626 Cars & Trucks
MY Pioneer VSX-826-K has just switched itself off and I can not get it to come back on?
try holding "advanced surround" and power buttons - it might be in protect mode.
Aug 07, 2014 | Pioneer Vsx 826 K Av Receiver Black
The TV has just switched itself off and the red standby light is blinking. It cannot be turned on using the remote. Using the manual on button on the TV will turn it back on for a few seconds before it...
The problem of your tv is your main power supply it is already weak. In order to fix this problem you should be aware of the parts. Try to remove the back cover of your tv, but be sure to unplug it then follow the ac cord it will direct you to the main power supply. Try to observe if their is a leaky capacitor or a wet mark bellow the surrounding of the capacitor the wet mark is the oil of the capacitor, try to replace it with the same type but observe the polarity of the capacitor.
Jun 25, 2011 | Televison & Video
Key will not remove from ingintion switch
Try pushing the gear shift further forward in park with your hand and see if the key releases.
If this fails it may be the switch itself just under the centre console which surrounds your gear shift. Carefully but firmly pull up the centre console up and you will see a little 'plunger' switch the engages when the gear shift is at its furthest travel forward in park.
Mar 04, 2011 | 2001 Mercedes-Benz CLK-Class
Samsung propell problems
Hi, May i help ? Friend the power switch of your phone is short circuited thats why it turns off when press a key. you should clean the power switch surroundings.or resolder the power switch if necessary.
Feb 01, 2010 | Samsung Propel A767 Cell Phone
Direction on how to replace instrument cluster light burned on 2001 ford sport trac
  • Pry the plate around the radio/heat controls off.
  • Disconnect the 4WD switch connector at the switch.
  • Disconnect the foglight switch connector at the switch.
  • Disconnect the rear wiper switch connector at the switch, if equipped.
  • Remove the panel surrounding the cluster itself. Bolts above the steering wheel in the shroud.
  • Remove the instrument cluster. Should be four bolts.
  • If you have an illumination bulb out, replace it with a #194 or a #168 bulb.
  • If you have a warning light out, replace it with a PC74 bulb.
  • Installation is reverse of removal. TEST BEFORE YOU PUT EVERYTHING BACK IN.
You're done.
Nov 24, 2009 | 2001 Ford Explorer Sport Trac
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
NAD T742 Receiver Logo
53 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
