Question about Dirt Devil Vacuums
Power reach dirt devil belt replacement
Access belt
Kazong
  • 152 Answers
SOURCE: dirt devil vacuum belt
on the bottom of vacuum ther are 4 screws take them out then a cover should expose the roller the belt is right there
Posted on Jan 23, 2008
SOURCE: the belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Posted on Jan 13, 2009
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
nwj2468
  • 76 Answers
SOURCE: Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
Posted on Aug 22, 2009
  • 50 Answers
SOURCE: how to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Posted on Apr 09, 2010
How to change belt on dirt devil ultra handy vac
Unscrew the chrome plate from the bottom to access the belt. Watch the Brit do it on YouTube How to replace dirt devil belt on handyzip
Jul 14, 2017 | Dirt Devil Vacuums
Why does the belt keeps comming off
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Apr 28, 2014 | Dirt Devil Breeze Bagged Upright
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Dirt Devil FeatherLite Belt
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Change belt on dirt devil vacuum
It largely depends on the model you have. However, you can get any Dirt Devil replacement belt here:
Dirt Devil Belts
Oct 22, 2009 | Dirt Devil Vacuums
Vacuums Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
