Question about Sennheiser Electronic SENNHEISER RI 150 Wireless Headphones
Adaptation of the mono Sennheiser IR headphone sold as the 50/55 TV set to make it stereo
If I am correct, the same set, is also available in a stereo version. This is the mono version. Is there a way to adapt the headphone / transmitter, to make it stereo? Or is the transmitter transmitting only in mono? If so, is there a way how I could alter the device, to have it as a stereo headphone set? The headphone is the RI50 headphone and the IR transmitter being the TI 50, together being sold as the 50/55 TV set. I would suspect, that the set is stereo and only by connecting the 2 channels together, being made mono. So, that would make it easy, to make it stereo again. I opened the device, to see or I could "decode" the schematic just by eye. I could not. The receiver has 2 IR eyes, and therefore I suspect that the device is receiving stereo, and made mono on the PCB. For me, the mono headphone is useless. I only want to use it when it is stereo. I received it for free, so, if it does get broken in the way to make it stereo, its a pity but not a huge loss.
5 Suggested Answers
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
ializar
SOURCE: power light blinks on both
Hello.
I have the same problem of blinking lights on both and no sound received...
Have you solved the problem ???
If the answer is yes can you tell ne something more through my mail ializar@hotmail.com ???
Thank you very much.
Posted on Apr 03, 2013
  • 109 Answers
SOURCE: sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Posted on Nov 07, 2013
Testimonial: "The TV has inputs but no outputs. I'm trying to hook up the headphones, but there's no where to plug them in (the stuff about the PS3 and receiver was just to give you an idea of what I was dealing with. In the back of the TV there is more jack but they're all input and apparently I need output..."
What could be wrong?
Put it in MONO mode.
You can also make a cable where the TIP and RING are wired together....
Oct 09, 2017 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
I don't have a remote and the tv is in mono how do
It will usually default to Stereo and still show mono--answer is to manually try (usually not possible) you need to get into the menu with the original remote---Philips at my last count had over 25 different IR codes for their products==many of which are not available with universal remotes etc.
May 02, 2012 | Philips Televison & Video
I have a Sanyo DP46841 TV and would like to hookup wireless speakers since i am hearing impaired. Can this be done and if so what are the best system to use? Jim
The Sennheiser Set 820S is a TV/music listening system specially designed for hearing aid wearers. With roughly a 100 foot range, Set 820S users can leave the room while still being able to listen to a TV program or music. Enhanced with radio frequency (RF) technology for a larger coverage area, users won't need to worry about missing a word of the program or song. The Set 820S consists of the 820 RF stereo transmitter and 820-S RF stereo bodypack receiver. The transmitter connects to a TV set or hi-fi system; the receiver can be clipped to clothing. The receiver can be coupled with an induction neckloop (sold separately) (hearing aid must have a t-coil), direct audio connection (to cochlear implants or BTE hearing aid) or Sennheiser headphones with a 3.5mm jack. Two year warranty. · Bodypack receiver · RF wireless transmission · Stereo or mono operation · Quick charge feature · High SPL (125dB) · Approximately 100 foot range · Maximum volume and bass response adjustable by hearing professional
http://www.mcssl.com/store/familyhearingcare/catalog/product/7f146beca0684d65a142df331ef59c00
wireless speakers are also available ........ but you may not hear 100% of sound............. click above shown link.... you will find many similar products ...... you can check thier price , features, etc & then you can finalise the one that suits you best ..............
Aug 09, 2011 | Sanyo Televison & Video
When I use the headphones listening to TV, I get the background sound (eg music) clearly but the dialogue is very low and drowned out by the background music or ambient sounds
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
Apr 18, 2011 | Bose QuietComfort 2 Acoustic Noise...
Hi... I cannot seem to capture my audio in stereo. The playback from my mic comes from one side (mono) only. How do I set it to play through both speakers? I have 2 input mics...1 one camera and my...
Your microphone has a stereo miniplug, with 3 contacts, that look exactly like headphone minijacks. You have not stated where you are trying to plug this microphone, but most computers /sound cards will accept only mono minijacks, with 2 contacts. Should you have left/ right inputs for microphones, buy a splitter adapter that will turn the stereo jack of the microphone into two mono jacks.
Aug 23, 2010 | Sennheiser (EW100ENGG2C) Professional...
I have Sennheiser HD 570 headphones. The plastic headband is broken where it attaches to the headphone. Can I order a new plastic headband and is difficult to replace?
That part isn't available from Sennheiser. But they are pretty maintainable, if you're good with mechanical things, and if you can come up with another set of the same headphones for parts.
If you've already replaced your headphones and want to rid yourself of the broken 570's, I'm looking for a set to scrounge for parts.
Aug 17, 2010 | Sennheiser HD 570 Consumer Headphones
How can use a set of headphone on my TV? I believe that I can use a RCA connector of some-sort. Can anyone help me?
The exact details of your headphones will matter. If you have a set that gives stereo and connects to your computer, you need a 3.5 mm mini plug (stereo) to RCA (two 1/3" prongs IIRC) adapter. If the headset was for some other devices, the adapter will be a 2.5 mm plug to RCA. (If you have mono headphones, get the mono version of the adapter.) The RCA audio plugs are usually red and white or black for audio.
I hope this helps.
Mar 20, 2010 | Toshiba 32AF43 32" TV
Open Questions:
See all Sennheiser Electronic SENNHEISER RI 150 Wireless Questions
Sennheiser Electronic SENNHEISER RI 150 Wireless Headphones Logo
115 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
