Question about John Deere 318D SkidSteer
Cant get bucket or arms to move hydraulic filter restriction light is on
    Top Expert:
  • John Deere Master
  • 10,875 Answers
Change the filter
Posted on Apr 24, 2015
What would cause my hydraulics to keep heating up on a 648g3 skidder?
Friction is usually the cause of hydraulic overheating. Every time the hydraulic oil moves through the system the moving of the hydraulic fluid against the hoses,pumps, cylinders , etc. creates friction. Any restrictions such as valves or filters can be hot spots because of the friction created as the passages get smaller the fluid moves faster creating more friction. Friction = Heat.
I would check the filters to make sure they are clean. Check the valves to make sure they are opening fully. Check hoses for any kinks or pinched spots.Try to operate the skidder at the lowest r.p.m. need for the work being done. Over revving can also cause heat buildup.
Hope this helps.
Bob
Dec 16, 2014 | Cars & Trucks
Why front bucket nor rear lift arms will not move?
by your description im assuming that your rerfering too a tractor , with it seems none of your hydraulic implements that move, i guess first thing to ck is proper fluid level in hydraulic res tank (not confused with engine oil) second is to make sure hydaulic pump is turning some tractors use a Pto drive shaft right off the transmission or front of engine and others use a belt that drives off the water pump need to ck all these things
Aug 28, 2014 | Cars & Trucks
My 2006 Pontiac Torrent lose power when I reach the speed of about 75-80
That is an odd bit of advice. If the oil pump was working poorly enough to cause a noticeable difference on engine performance, then you have already ruined the engine.
Although not always the case, typically if you are losing power as you increase speed, it is a fuel problem. Fuel pump could be going out. Inline fuel filter could be dirty and restricting fuel flow. Intank (gas tank) filter could be clogged and restricting fuel flow.
Regarding your oil pump, you can check to see if it is working correctly by installing an oil pressure gauge. You might check to see if your engine has solid lifters or hydraulic lifters. If it has hydraulic lifters, your engine will develop a tapping noise when the oil pressure is low because the lack of oil pressure creates a lack of hydraulic lift in the lifters and so they collapse creating a gap between the lifter and the rocker arm. This gap means that the rocker arm comes off the lifter and then smacks the lifter when coming back down resulting in the "tapping" noise mentioned.
Jun 23, 2014 | 2006 Pontiac Torrent
Oo.comi have a 873 bob cat 2000 and it will move forward and back but the arms wont go up and down i do have up and down tilt on the bucket
Does foot pedal move? If not could be slide lock not being pushed down far enough. Or newer models could be spool lock on valve. Worst case bent or seized lift spool in valve or cylinders by passing internally.
Sep 23, 2011 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Mss-SR Mitsubishi excavator moves and lifts lowers
We may have a similar problem. Email me at ehenderson@minewise.net
Jul 19, 2009 | Garden
John Deere 318D SkidSteer Logo
966 people viewed this question
Top John Deere Welding Tools Experts
Bill Boyd
Are you a John Deere Welding Tool Expert? Answer questions, earn points and help others
