Question about Garden
Replaced the drive belt and now the rod spring bypass lever is not connected - need directions to reinstall rod spring bypass
    Top Expert:
  • 10,875 Answers
What tractor,need numbers under the seat to get info
Posted on Apr 24, 2015
Why will throttle on Mantis 4 cylinder tiller not move when we pull the lever?
The engine is likely to be speed governed in some way. Depending on the method employed there is likely no direct connection between the throttle lever and the throttle butterfly, assuming it is a petrol engine.
Unless it is fitted with a governed carburettor, which would have a direct connection, the throttle lever is usually connected to the throttle butterfly by a fairly weak spring. When the throttle lever is moved to increase the engine speed, as the speed rises the governor which is also connected to the throttle butterfly will pull back tending to close the butterfly until the throttle spring and the governor are equal to each other and an increased stable speed is achieved.
A degree of maintenance is usually needed as the spring(s) rust and fall off, the rods and pivots become bent, worn, detached or seized...
Jun 18, 2017 | Mantis Garden
Why will my Gx325 John Deere not go in forward or reverse
For a more precise answer give the Year/Hours on Meter, and a brief description of the events prior to the problem. When did it last run correctly? What has happened since then?
The first questions that comes to mind...
  1. Can you manually push the mower around?Easily?
  2. We need to know if the brakes are locked up?
  3. We need to know if the transmission bypass lever is in or out?
  4. With the bypass lever out, brakes off, can you roll the machine?
  5. Is the bypass lever still properly connected and unbent?
  6. Looking under the machine (right in the center above the cutting head) are the drive belts intact?
  7. Do the drive belt idler pulleys/bearing look ok?
  8. Is the drive belt engagement plate still connected to the foot pedals?
  9. Does the pulley wheel and fan on the transmission spin when the motor is running? (is power going to the transmission?)
These are your first things to check. You may have to remove the cutting head to fully examine these things.
Mar 10, 2015 | John Deere Garden
My john deere la 105 will not go forward or reverse, what's wrong?
Check your transmission belt from engine to rear diff. Up high above the deck belt. Its either broken or off its pulleys possible
Sep 24, 2014 | John Deere Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
Hoow to set up the timing belt
What do you mean by drive belt. If your talking about the serpentine belt, it should have an auto tensioner. Same goes for the timing belt. There is no adjustment. If the belt is loose then it needs to be replaced.
Replacing timing belt,Sienna 1998:
1.Disconnect battery (-) cable and plastic wiper washer cowl assembly
2.Remove spark plugs and put all wirings,cables out of the way
3.Drain coolant (cold) and remove upper hose
4.remove front right tire and wheel plastic fender apron
5.jack up engine under oil pan with rubber,towel or wood slightly
6.remove right engine support rod and its bracket
7.remove all drive belts.Examine condition;Label if re-using
8.remove plastic upper timing belt cover & gasket
9.remove crankshaft pulley bolt-use the ff. methods: a.air impact wrench or Toyota Special service tool-best b.chain wrench on pulley then breaker bar/socket on bolt-good c.open fly wheel cover,jam screwdriver on gear teeth then unbolt-tough d.breaker bar/socket on bolt, jam bar tip on floor, lower car then "start" engine -smart
10.remove pulley by hand or use carefully 2 prybars then remove plastic lower T.B.coverand gasket
11.reinstall bolt and turn engine clockwise to align timing marks:one on each camshaft sprocket and one on the crankshaft sprocket
12.remove T.B. tensioner spring-2 bolts loosen alternately then keep upright
13.remove crankshaft sprocket guard then the sprocket, then the belt.
14.Examine belt condition for damage and correct cause of damage if any
15.remove idler T.B.pulleys & check for smooth operation/contamination/leak
16.check all oil seals, water pump leaks,etc
17.Check T.B.tensioner spring for oil leak and tension by pressing push rod against hard object-there should be no movement or leak
18.Compress push rod using vise, align rod hole with outer hole then insert small nail, pin or wire to keep it there then reinstall along with other parts removed
19.Install T.B.carefully.No twist, stretch,prying ,oil, moisture, bending
20.Handturn engine 720 deg.clockwise, feel for resistance , and then see timing marks still re-align
21.Reinstall plastic covers and gaskets,drive belts.etc in reverse order 21.
Hope this helps.
Mar 02, 2011 | 1998 Toyota Sienna
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
How do i put timing belt and water pump?
REMOVAL & INSTALLATION of timing belt: Fig. 1: View of the timing belt cover 91163p64.gif
Fig. 2: Loosen then timing belt tensioner using a ratchet and short socket 91163p65.gif
Fig. 3: Matchmark the direction of rotation of the timing belt 91163p67.gif
Fig. 4: Once loose, pull the belt off the camshaft pulley 91163p71.gif
  1. Disconnect the negative battery cable.
  2. Turn the crankshaft to align the timing belt matchmarks and set cylinder No. 1 to Top Dead Center (TDC) on the compression stroke. Once in this position, the engine must NOT be turned or disturbed.
  3. Remove all necessary components to gain access to the cylinder head and timing belt covers.
  4. Remove the cylinder head and timing belt covers.
  5. There are 2 belts in this system; the one running to the camshaft pulley is the timing belt. The other, shorter one drives the balance shafts and is referred to as the balancer belt or timing balancer belt. Lock the timing belt adjuster in position by installing one of the lower timing belt cover bolts to the adjuster arm.
  6. Loosen the timing belt and balancer shafts tensioner adjuster nut, but do not loosen the nut more than 1 turn. Push the tensioner for the balancer belt away from the belt to relieve the tension. Hold the tensioner and tighten the adjusting nut to hold the tensioner in place.
  7. Carefully remove the balancer belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys.
  8. Remove the balancer belt drive sprocket from the crankshaft.
  9. Loosen the lockbolt installed to the timing belt adjuster and loosen the adjusting nut. Push the timing belt adjuster to remove the tension on the timing belt, then tighten the adjuster nut.
  10. Remove the timing belt. Do not crimp or bend the belt; protect it from contact with oil or coolant. Slide the belt off the pulleys.
  11. If defective, remove the belt tensioners by performing the following:
    1. Remove the springs from the balancer belt and the timing belt tensioners.
    2. Remove the adjusting nut.
    3. Remove the bolt from the balancer belt adjuster lever, then remove the lever and the tensioner pulley.
    4. Remove the lockbolt from the timing belt tensioner lever, then remove the tensioner pulley and lever from the engine.
  12. This is an excellent time to check or replace the water pump. Even if the timing belt is only being replaced as part of a good maintenance schedule, consider replacing the pump at the same time. To install:
  13. If the water pump is to be replaced, install a new O-ring and make certain it is properly seated. Install the water pump and retaining bolts. Tighten the mounting bolts to 106 inch lbs. (12 Nm).
  14. If the tensioners were removed, perform the following to install them:
    1. Install the timing belt tensioner lever and tensioner pulley. NOTE: The tensioner lever must be properly positioned on its pivot pin located on the oil pump. Be sure that the timing belt lever and tensioner moves freely and does not bind.
    2. Install the lockbolt to the timing belt tensioner, do not tighten the lockbolt at this time.
    3. Install the balancer belt pulley and adjuster lever.
    4. Install the adjusting nut and the bolt to the balancer belt adjuster lever. Do not tighten the adjuster nut or bolt at this time. NOTE: Be sure that the balancer lever and tensioner moves freely and does not bind.
    5. Install the springs to the tensioners.
    6. Move the timing belt tensioner its full deflection and tighten the lockbolt.
    7. Move the balancer its full deflection and tighten the adjusting nut.
  15. The crankshaft timing pointer must be perfectly aligned with the white mark on the flywheel or flex-plate; the camshaft pulley must be aligned so that the word UP is at the top of the pulley and the marks on the edge of the pulley are aligned with the surfaces of the head.
  16. Install the timing belt over the pulleys and tensioners.
  17. Loosen the bolt used to lock the timing belt tensioner. Loosen, then tighten the timing belt adjusting nut.
  18. Turn the crankshaft counterclockwise until the cam pulley has moved 3 teeth; this creates tension on the timing belt. Loosen, then tighten the adjusting nut and tighten it to 33 ft. lbs. (45 Nm). Tighten the bolt used to lock the timing belt tensioner.
  19. Realign the timing belt marks, then install the balancer belt drive sprocket on the crankshaft.
  20. Align the front balancer pulley; the face of the front timing balancer pulley has a mark, which must be aligned with the notch on the oil pump body. This pulley is the one at 10 o'clock to the crank pulley when viewed from the pulley end.
  21. Align the rear timing balancer pulley (2 o'clock from the crank pulley) using a 6 x 100mm bolt or rod. Mark the bolt or rod at a point 2.9 in. (74mm) from the end. Remove the bolt from the maintenance hole on the side of the block; insert the bolt or rod into the hole. Align the 2.9 in. (74mm) mark with the face of the hole. This pin will hold the shaft in place during installation.
  22. Install the balancer belt. Once the belts are in place, be sure that all the engine alignment marks are still correct. If not, remove the belts, realign the engine and reinstall the belts. Once the belts are properly installed, slowly loosen the adjusting nut, allowing the tensioner to move against the belt. Remove the pin from the maintenance hole and reinstall the bolt and washer.
  23. Turn the crankshaft 1 full turn, then tighten the adjuster nut to 33 ft. lbs. (45 Nm). Remove the bolt used to lock the timing belt tensioner.
  24. Install the lower cover, ensuring the rubber seals are in place. Install a new seal around the adjusting nut, DO NOT loosen the adjusting nut.
  25. Install the key on the crankshaft and install the crankshaft pulley. Apply oil to the bolt threads and tighten it to 181 ft. lbs. (250 Nm).
  26. Install the upper timing belt cover and all applicable components. When installing the side engine mount, tighten the bolt and nut attaching the mount to the engine to 40 ft. lbs. (55 Nm) and the through-bolt and nut to 47 ft. lbs. (65 Nm).
  27. Connect the negative battery cable.
For water pump removal and installation contact me:
Jul 12, 2010 | 1997 Honda Civic
Drive stopped working
There is an idler pulley inside the deck with a spring. The belt probably jumped of the idler which would result in the drive cable being slack. You can probably fix this yourself by re-routing the belt so that the idler with spring engages the belt. Depending on the condition of the belt you may have to losen all of the engine mount bolts so re-route the belt properly. I have had to take out all but ONE engine bolt (left loose) to install a belt.
If you need details on bolts / covers that need to be removed I need the whole model number to be of further asistance.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Mtd 22" White Outdoor Self Propelled High...
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
