Question about Jeep 2007 Grand Cherokee Laredo
Where is the coolant sensor on my jeep, as the check engine light come on and the vehicle is not overheating but the radiator fan is not coming either . i've replaced the 30 aamp fuse,nothing
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 103 Answers
Radiator fan will engage if engine is hot, if not, relay for fan or fan may be inop.
Coolant sensor can also be in the coolant resevoir, and on the intake manifold area.
Posted on Sep 09, 2016
Why is the temperature light keep coming on and the gauge keep going up and down?
Temperature Warning Light is on Inspection Service How this system works: With the exception of older, air-cooled vehicles, cars rely on a liquid called coolant (or antifreeze) to keep the engine at an optimal temperature. Coolant is a mixture of water and ethylene glycol, and it circulates around the engine block and absorbs excess heat, which keeps the engine from overheating. The coolant converts that heat to air in the radiator, and then the air is emitted, at which time the coolant is ready to absorb more heat. Without coolant, the engine would quickly ruin itself with its own heat production. Common reasons for this to happen:
  • Coolant is low or weak: The most common culprit when an engine overheats is low or weak coolant. If your car doesn't have enough coolant, then it can't absorb enough heat. While your car will naturally lose small amounts of coolant over the years, a leak is the most likely cause of low coolant levels.The proper ratio of coolant to water can also get distorted, resulting in a problem. Too little or even too much antifreeze can dramatically lower the boiling point of the coolant. A proper ratio of antifreeze to water is 50/50 to 60/40, depending on the vehicle.
  • Broken radiator fan shroud: The radiator fan shroud directs the airflow across the radiator so the air can absorb the coolant's heat. When the fan shroud breaks or becomes dislodged, air fails to enter the radiator, and the coolant will no longer have a place to direct the transfer of heat.
  • Broken or missing air dam: Along with the shroud, some vehicles have an air dam (or deflector) underneath the vehicle. If this is broken or missing then the air can pass underneath the vehicle but not also through the radiator, which will cause overheating. These air dams are essential in newer vehicles, as they force the air through the fan shroud.
  • Faulty coolant temperature sensor: The temperature sensor takes constant readings of the coolant temperature and sends that information to the engine control unit. Based on the temperature of the coolant, the engine control unit adjusts the ignition timing, the fuel injector pulse, and the operation of the electric cooling fan.
  • Bad water pump: The water pump is responsible for keeping the coolant cycling throughout the engine. After the coolant transfers its heat energy to the air, the water pump recirculates it around the engine so that it can absorb more heat. The most common water pump problems are a leaking pump, bad bearings, or an impeller that has rotted away due to a low coolant ratio.
  • Stuck thermostat: The thermostat acts as a dam for the coolant. When the engine first turns on, and it is still cold, the thermostat keeps the coolant from circulating, which allows the engine to warm up as quickly as possible. Once the engine has reached its operating temperature, the thermostat opens and allows the coolant to circulate. A stuck thermometer may stay permanently sealed and therefore keep the coolant from reaching the engine block.
  • The thermostat may also stick open. This will not usually result in overheating, but it will waste gas.
  • Broken engine cooling fan: The engine has a cooling fan that is deployed when the coolant needs some extra help. When the coolant temperature sensor notices that the coolant temperature is getting too high, the engine control unit (on newer vehicles) will initiate the cooling fan to reduce the temperature.
  • Broken thermostatic fan clutch: Older vehicles use a thermostatic fan clutch to engage the engine cooling fan, which is mounted to the fan blades. The fan clutch uses a bi-metallic spring that tightens when the temperature increases. This acts as a "high speed" option for the fan, and when engaged, it draws more air across the radiator.
  • Blown head gasket: The head gaskets sit between the engine block and the cylinder heads, and keep coolant from entering the engine's oil and combustion chamber. When a gasket blows and coolant seeps in, the issue is not only that the engine will overheat, but also that damage may be done to the catalytic converter and oxygen sensors due to contamination from the coolant. What to expect: A top-rated mobile mechanic will come to your home or office to determine the cause of the temperature warning light turning on and the source of the overheating, and will then provide a detailed inspection report that includes the scope and cost of the necessary repairs. How important is this service? An overheating engine is extremely dangerous. It is not safe to drive a vehicle with an overheating engine, or you may ruin the engine completely and put yourself at risk. As soon as you notice the light come on, pull over. If there is no place to safely pull over, turn off your radio and other electrical units, and turn your heat on high (this will funnel some of the hot engine air into the cabin). As soon as you can safely pull over, do so, and then book one of our mechanics to perform an inspection.
Sep 30, 2016 | 2008 Pontiac G6
How can we bypass the cooling sensor by the thermostat?
Om most vehicles, you can't. The coolant temperature sensor sends a variable signal to the ECM based on coolant temp, and that value is used by the ECM in the computation of the fuel mix (rich/lean) to the injectors. Without it, the vehicle will run poorly, if at all, and will set the Check Engine Light. There MAY be a separate coolant sensor that simple controls the radiator fan. This one could be bypassed, but that comes with great risk of engine overheating and damage. Most newer cars use the coolant temp sensor for both the fuel mix and the radiator fan with the fan on/off signal controlled by the ECM.
Oct 11, 2015 | Cars & Trucks
2002 ford windstar sel overheating
first check coolant level in radiator coolant level sound low.if coolant overflow jug empty.coolant sysyem low, when add coolant to coolant overflow jug coolant level should stay at full cold mark.if coolant level okay,engine overheat while sitting or moving in slow traffic either coolant fan relay or fuse could be bad.or engine coolant temperature sensor could be bad. coolant sensor turn on cooling fan at certain temperature.hot wire check to make sure cooling fan motor not bad or short in wires.if all is good have pcm check it controls fan relay to through the coolant temperature sensor signal when coolant get hot.
Nov 04, 2012 | 2002 Ford Windstar
Will a leak cause the radiator fan relay curcuit to malfunction on a 2003 jeep liberty 3.7
a leak in coolant system will cause air pocket in the coolant system around the engine coolant temperature sensor.coolant sensor is a thermistor in which when hot cool cause it resistance decrease which affect the voltage from sensor to pcm which will cause engine coolant to turn on.if coolant level okay,check coolant fan fuse and relay, if all is good,engine coolant temperature sensor could be bad or have vechicle code scan for pcm problems it control the coolant fan.fill coolant system to correct level make sure engine coolat reservoir is at full cold mark and not empty.fill coolant system check for leaks,refill coolant overflow jug back to full cold mark dont over fill, if coolant overflow stay empty you have leak either its leaking or you have radiator hoses or radiator leaking coolant.when coolant overflow jug run dry it cause air get in coolant system causing overheating problems.
Jul 25, 2012 | 2003 Jeep Liberty
Replaced water pump due to overheating, now overheating again and computer says low engine coolant when I check water its fine. could this be the thermostat? where is the thermostat located on 1997 Aurora?
Since you replaced the pump, the coolant reservoir probably got empty during the process and sometimes the level sensor inside it tends to get stuck. Look at the reservoir and on the bottom of it there should be some wires coming out of it, that's where the level sensor is. Lightly tap it with a pair of pliers and it should come up therefor removing the low coolant light. Now for the overheating, turn on the car and let it come up to temp, open the hood and make sure your fans come on when they're suppose to. If the temp is going higher and the fans don't come on then you need to check the fan relays or the coolant sensor. Turn on the ac, the condenser fan should start up, see if that helps it cool down. If the radiator fan does not come on, unplug it and plug it straight to the battery to see if it turns on, if not, you need a new fan, if it works then like i said, relays, fuses, sensor. Oh, i almost forgot, replace the THERMOSTAT as well.
Aug 25, 2011 | 1997 Oldsmobile Aurora
Overheating
OVERHEATING CAN BE CAUSE BY MANY THINGS LIKE FAULTY THERMOSTAT AND FAULTY RADIATOR PRESSURE CAP,TOO MUCH WATER IN COOLANT SYSTEM NEED 50 / 50 WATER AND ANTIFREEZE.LOOK FOR WATER PUMP WEEP HOLE LEAK, IF COOLANT LEAKING OUT WEEP HOLE WATER PUMP BAD NEED REPLACING.CHECK FOR LOW COOLANT LEVEL, YOUR RADIATOR OVERFLOW JUG SHOULD HAVE COOLANT AT THE FULL COLD MARK IF NOT KEEP ADDING COOLANT INTO COOLANT OVERFLOW JUG UNTIL COOLANT STOP DROPPING AND FULL COLD MARK, IF OVERFLOW COOLANT JUG WAS EMPTY RADIATOR IS LOW ON COOLANT.WHICH CAUSE AIR IN COOLANT SYSTEM KEEPING THE ENGINE COOLANT TEMPERATURE SENSOR FROM BEING SUBMERGE IN HOT COOLANT WHICH TURN ON THE COOLANT FANS.WHEN ENGINE COOLANT TEMPERATURE GET CERTAIN SET TEMPERATURE LIKE 190 DEGREES THE PCM AND COOLANT SENSOR WILL TURN ON COOLANT FANS, IF VECHICLE OVERHEATING COOLANT FANS NOT WORKING EITHER YOU HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR CHECK COOLANT FANS FUSE AND RELAYS. YOU CAN CODE SCAN CAR TO SEE IF YOU HAVE FAULTY PCM, FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR FAULTY COOLANT FAN RELAY.IF COOLANT FAN AND ENGINE COOLANT TEMPERATURE SENSOR OKAY,YOU HAVE CORRECT COOLANT LEVEL IN COOLANT SYSTEM, THERMOSTAT AND RADIATOR PRESSURE CAP BEEN REPLACED, YOU COULD HAVE BLOWN HEAD GASKET CHECK ENGINE OIL LOOKS LIKE MILK SHAKE HEAD GASKET BLOWED ALSO WHEN HEAD GASKET BLOWED YOU CAN DRIVE CAR SHORT DISTANCE START OVERHEATING AND YOU LOOSE ENGINE POWER SUSPECT BLOWED HEAD GASKET.
Aug 04, 2011 | 1999 Oldsmobile Alero
Overheating
CAR OVERHEATING FIRST CHECK FOR LOW COOLANT IN THE RADIATOR COOLANT OVERFLOW JUG.IF COOLANT LEVEL IN OVERFLOW JUG LOW REFILL ADD COOLANT BACK TO THE FULL COLD MARK.PUT RADAITOR CAP ON COOLANT OVERFLOW JUG START ENGINE LET IT IDLE UNTIL IT OPERATING TEMPERATURE.MAKE SURE TOP RADIATOR HOSE GETTING HOT WHILE ENGINE WARM UP.IF TOP RADIATOR HOSE DONT GET HOT WHILE ENGINE IDLING YOUR THERMOSTAT COULD BE STUCK CLOSE CAUSING CAR TO OVERHEAT.IF TOP HOSE IS GETTING HOT.CHECK FOR COOLANT LEAKS CHECK TOP RADIATOR HOSE AND BOTTOM RADIATOR HOSE FOR LEAKS.CHECK FOR LEAKS AT THE RADIATOR CORES AND PLASTIC SIDE CONTAINERS.IF ALL IS GOOD ENGINE OVERHEATING WHILE IN A LONG TRAFFIC LINE, COOLANT FANS NOT COMING ON.COULD HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR BLOWN COOLING FAN FUSE OR RELAY.COULD HAVE PCM FAULT.MAKE COOLING FAN ELECTRICAL CONNECTORS AND WIRING NOT DAMAGE OR BROKEN.
Jul 17, 2011 | 1999 Oldsmobile Alero
Overheating Problem with 2003 Bonneville. I have
The one thing I would check first is the cooling fan a quick check is with engine running turn a/c on and see if radiator cooling fans are running, if they are then we know the the fan's are good, if they don't come on check voltage at cooling fan if you have voltage bad cooling fan, turn car and a/c off, start car again with a/c off and fan's should come on at about 220deg. if they don't come on disconnect coolant temp sensor fan should come on, more then likely bad coolant sensor, now if fan don't come on you'll need check check your radiator or have a radiator flush.
Apr 01, 2010 | 2003 Pontiac Bonneville
Vehicle is overheating
electric fans or belt driven? if electric are they kicking on?
Feb 22, 2010 | 2003 Jeep Grand Cherokee
Jeep 2007 Grand Cherokee Laredo Logo
139 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
