Question about Krowne Metal Mc48b Glass Froster - MC48B
Hw to set temperatures - Krowne Metal Mc48b Glass Froster - MC48B
Taco 007 circulating pump stays on even though boiler shuts down
Don't know your specific unit, but in general, heating systems are two-stage devices:
1: Its too cold: the motorised HW/CH valve moved to the required position, and on achieving it, the circulaion pump starts and the boiler is enabled. (The circ pump may start immediately - its not usually important.) The hot water from the boiler circulates through the heat exchanger and/or radiators until the thermostat thinks its target is warm enough, whereupon it disables the boiler, stops the pump and closes/relaxes the valve(s).
2: The boiler is off while disabled. When enabled, it heats the circulating water to a 'high' temperature and seeks to keep it there. If it reaches that temperature, the boiler will cycle on and off as necessary to maintain the set 'high' temperature. (The circulation pump must run all the time the boiler is enabled.) This may be what you're noticing. Additionally, some boilers will run the circulation pump for a little while after being disabled to reduce the temperature if the water in the pipes and boiler.
Your question doesn't say how the pump running corresponds to thee thermostat settings, but if it were stuck on, I think you'd know!
Dec 31, 2016 | Water Heaters
Changing the temperature Button does not work. WHY?
are you giving it time to change, it either needs time to heat or cool the water it is not instantaneous in its operation.
Jan 01, 2016 | Haier washer HW-E1070TVE User Manual
My shower water temperature is way too hot. How do I reduce it?
go to the hot water heater and turn it down 1\2 way a start from there
Jul 19, 2011 | Heating & Cooling
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
6500 Slide Cellular Phone: hw i make configuration setting...
to get gprs setting
u just call CC and ask them to send the setting
they have all settings for ur phone
becoz ur using nokia phone
May 06, 2010 | Nokia 6500 Slide Cellular Phone
Could you please guide me how to remove bois possword for travel mate5730g
Steps for Clearing BIOS Password Check
If users set BIOS Password (Supervisor Password and/or User Password) for a security reason, BIOS will ask
the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
• Power Off a system, and remove HDD, AC and Battery from the machine.
• Open the back cover of the machine, and find out the HW Gap on M/B as picture.
• Use an electric conductivity tool to short the two points of the HW Gap.
• Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
• Restart system. Press F2 key to enter BIOS Setup menu.
• If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password (Supervisor Password and User Password).
Check below for the picture of the HW Password reser gap. The gap that needs to be "shorted" is G77.
Jan 27, 2010 | Acer TravelMate 5730-6204 Notebook
Hw to open gprs
text SET 6070 and send to 211
May 09, 2009 | Nokia 6070 Cellular Phone
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Krowne Metal Mc48b Glass Froster - MC48B Logo
662 people viewed this question
Top Krowne Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
Don A
Don A
Are you a Krowne Wine and Spirit Expert? Answer questions, earn points and help others
