Question about Garden
My z155 is blowing smoke for about 2 hrs riding it has about 20 hrs ride time on it ,it has lost power ,would this be my valves and if so what is the clearence plz.has oily exaust tip inside
  • 1,169 Answers
More likely a blown gasket head. A leak-down should tell you if this this the problem.
Posted on Apr 24, 2015
mowerman1857
  • 389 Answers
SOURCE: Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Posted on Sep 15, 2009
  • 7 Answers
SOURCE: New Craftsman 20hp Briggs & Stratton 42
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Posted on Jan 25, 2010
RonInFla
  • 86 Answers
SOURCE: i have a riding mower and it runs but lack power
if it's a 2 cylinder (should be) 1 spark plug is fouled out...rule-o-thumb...replace both...that's step 1...
Posted on Apr 28, 2010
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
smitty5609
  • 243 Answers
SOURCE: 42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Posted on Sep 30, 2011
Have john deere d120 ride single cyl B&S 21hp they are prone to head gasket failure after 50 hrs.Would having the head retensioned reduce this happening would valve clearances need rechecking. Thanks
has the head gasket failed already or are you surmising that it will happen soon
having the head studs re-tensioned would help reduce the possibility of it happening as the studs are small in diameter and can stretch and loose tension
it would be advisable to check the valve clearance as B&S valves tend to stretch and that makes start when hot difficult
Dec 01, 2017 | John Deere Garden
Blowing white smoke out of exhaust
sounds like it is still overfilled ,, oil is leaking on the back side of the piston .. or may be a blown head gasket and being overfilled was just a coincidence if it is a briggs motor I would be suspect of a head gasket.
May 24, 2015 | Husqvarna YTH2042 42" 20 HP Lawn Tractor...
2000 sv650
I would be checking for gunk in the main jet tat has come from the tank since starting
indications are from wide open throttle just to keep it at idle
Dec 20, 2017 | 2000 Suzuki SV 650
I have a 21 H.P. in my John Deere riding mower and it started blowing blue smoke out of exhaust excessively, I think i might have have blown a valve seal because motor still runs fine, just provides...
first check the oil and sill if it has a heavy gas smell there has been a lot of needle valve problems in carb lately then i would do a compression test they have been known to blow head gaskets and with over head valves there is oil up in the cylinder heads and a valve seal wouldn't be a constent flow of smoke
Jun 10, 2012 | Garden
2002 Honda VT 750 CD Shadow A.C.E. Deluxe blowing smoke
Hi, Maria your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
02 750 ACE is now smoking
Identifying Smoke
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 23, 2012 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Craftsman 21 hp 42in.deck model nimber 944.600110 white smoke
check the oil if it smells like gas change the needle valve and seat in the carb and change the oil
May 17, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Apr 28, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Briggs & Stratton motor
try a new coil
Mar 23, 2012 | Garden
My 07 KTM 525 blows smoke and uses all the oil arter 2 hrs of riding, It was sitting for about 1 year and never used oil before
One of the disadvantages of parking a bike for such a long time. One of 2 things have happened.(Or maybe both.)
Valve stem seals have hardened.
Rings have become gummed up.
Either way you'll need to get the head and barrel off. I've heard of mixing a table spoon brake fluid with a cup of petrol and running that through the carb. I dont recommend it as I've not tried it. Rather try something like valve ease. Dont use it too often. The graphite tends to clog filters. I've also used acetone on my 4X4 but be VERY careful. Use only about a teaspoon full per litre of fuel.
Aug 02, 2010 | KTM EXC 525 Racing Motorcycles
27 hp kohler v-twin ohv backfires, and @ times blows white or black smoke
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
