Question about LG Televison & Video
How do I fix no video but sound on an LG smart TV ?
I replaced the T-con control board and still the same problem. The TV powers up and the LG symbol appears for a brief moment and the screen goes blank. I hear sound and when attached to cable, I hear the channel playing! What do I need to replace ?
  • LG Master
  • 681 Answers
Hi Michael,
This is the sad story of many a so called smart TVs. I have repaired several of Samsung smart TVs. It is the back light in the panel which fails and company guys advise you for a panel replacement. Once you can see LG symbol means the Tcon is working. It is not the picture which is disappearing, it is the failed backlight which is not there and so you can not see anything. Repairing panel is a tricky job and you need a certain amount of expertise for this. Otherwise you may damage it beyond repairs.
Posted on May 03, 2015
    Top Expert:
  • LG Master
  • 74,251 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 25, 2015
    Top Expert:
  • LG Master
  • 6,702 Answers
You can replace almost everything in the TV and still don't have video, when you forget to replace the defective part. Don't replace what you believe is defect. Not even replace things you are convinced they must ben defect. Only replace this things you found to be defect after correct measurements and good diagnose. That is what a tech, after years of learning and practicing his job gives as an advice. Please when you can't do the diagnose yourself, ask a tech or bring it to a repair shop. It will save you lots of time, frustration and money.
How can I tell if my main board in my 47LN5700 LG TV is no good
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 22, 2017 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
Tip
Tv problems lg and vizeo
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
on May 22, 2015 | LG Televison & Video
Can i repair my LG LED/LCD TV?
hi this could be a bad ribbon, or bad panel thanks
shaun
Feb 12, 2017 | LG Televison & Video
LG 55LM4600-UC LED TV I have was squirted with a squirt gun. Would replacing the t-con board fix this tv? Please read further details.
when water shorts out something it overloads a lot of other components so the best advice is to take it in for a proper diagnosis.
you just replace a board but another board is damaged it might just blow the board you replaced and that would prove nothing
Jan 09, 2017 | LG Televison & Video
After a thunder storm i have sound, no picture, the tv powers up, the back lights are on, should i suspect a bad lcd screen?
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Mar 11, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
Has sound. Why did picture suddenly go black?
The T-Con board controls the picture. This board has two flat ribbon cables that connect to the bottom of the screen. You can get a replacement and fix it yourself from here. TV Parts Universal TV Stands DLP Chips ShopJimmy You may find a you tube video on how to do the repair. Just log on to You tube and type in T-Con replace.
Feb 07, 2016 | LG 55LA7400 55IN CLASS CINEMA 3D 1080P...
No back-light,No picture, but has sounds. How can I fix it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 03, 2015 | Vizio E500i-B1 50-Inch 1080p Smart LED...
I have a LG 50LN5600 LED Smart TV w/sound no/pic Have replaced the power supply board and t-con board. Main board only one left and research says that this would not be a main board prob. Any help?
If the LCD panel back light is not lit you have a bad LCD panel. If the back light stays lit when the set is turned on then you almost certainly have a bad main board since you have already replaced the power supply and T-con.
Aug 17, 2015 | LG Televison & Video
Televison & Video Logo
373 people viewed this question
Computer Repairing
Computer Repairing
