Question about The Computers & Internet
I cannot install quick books 2002 pro from the memory stick unless I use the cd which I can't find.I have a 2008 version my laptop but cannot use for files from the older version. What can I do?
    Top Expert:
  • The Master
  • 45,441 Answers
Look harder than ever for the OLD disk .
Posted on May 14, 2015
QBPOSScott
  • 237 Answers
SOURCE: Converting QB Pro 2008 to QB Online
You can tell your data file size by having the program open and using Control+1 on the keyboard.
Depending on the complexity of the books, going to the On line version may not be your best choice as it has limited capabilities compared to the desktop versions.
Posted on Sep 15, 2008
dixibabe82
  • 54 Answers
SOURCE: Problem restoring Data
You should be able to locate your original files and make a backup copy to a neutral location. Once you do that, go to Control Panel and uninstall all versions of Quickbooks you see listed. Restart, reinstall 2002 or 2004, which ever you have the full install for, and then put a copy of your original files back in the designated folder that Quickbooks uses. You should be able to open 2002 now, and continue with 2004 upgrade. Let me know if you have trouble finding your origianl QB files and I can help you out with that too.
Posted on Mar 31, 2009
SOURCE: is quick books 2003 Vista compatabile?
QuickBooks Pro 2003 can run on Windows Vista. Right-click a shortcut to open Quickbooks (or qbw32.exe directly) and click on Properties. Select the Compatibility tab. Under Compatibility Mode, check the box and select Windows XP (Service Pack 2) from the list. Under privilege level, select "Run this program as an administrator." Select OK and everything will work.
Posted on Apr 06, 2009
drqbooks
  • 34 Answers
SOURCE: had to reinstall quick books pro 2002 in new
Go to: http://sharedldfp.intuit.com/pub/quickbooks/2002/
Posted on Feb 02, 2010
  • 195 Answers
SOURCE: Office 2007 Pro CD appears blank? No autorun, but
I'm really not sure what to suggest as the disc is not reading in multiple computers and other discs work fine on the computer you are trying to install it on it sounds like it is bad media. You may want to contact the location you purchased it from and see if you can exchange to software.
Posted on Jun 17, 2010
On Mac book pro, I have installed Axure software, Not able to open it.
Hi Satish
Did you download the Mac Version? .EXE files are for Win PC and won't run on a Mac (Unless you have used BootCamp to install Windows)
The Mac version downloads as a .DMG file (AxureRP-Pro-Setup.dmg) which is a Disk Image and should mount on the Desktop like a Hard Drive.
Apple now turn this off by default so goto Finder Preferences and turn on "Hard Disks" then "Advanced" / Tick "Show all filename extensions"
When the Disk Image shows on the desktop just open it and drag the actual App to the Applications folder (or Desktop). You could then drag it to the Dock at the bottom of the screen to make a quick shortcut (alias)
Also be aware that Apple try to protect your Privacy etc from unauthorised Apps. So if it opens with a warning, you can fix this by going to your System Preferences / Security & Privacy / General and click "Allow Apps downloaded from" click Anywhere.
Hope this takes care of your problem?
If So...Click HELPFUL
Cheers
Jul 03, 2015 | Apple MACBOOK PRO 15" A1211 T7400 2.33Ghz...
Tried to install xp instead of vista, now bootmgr is missing.
First you will need the SATA driver already saved on a memory stick. Now go into the BIOS and change the boot order: put the cd first then the hard disk second, save the new setting and reboot. Put the XP install and reboot again, the install will start. When instructed to input extra drivers plug in the memory stick and point to it. After that don't forget to install all the other drivers from here.
http://toshibatips.blogspot.com/2009/01/satellite-pro-l300-notebook-windows-xp.html
Jun 28, 2010 | Toshiba Satellite Pro L300 Notebook
How to install windows XP Pro without using cd drives
Find a computer with a CD-ROM drive.
Find a USB memory-stick that can hold 1 gigabyte.
Copy all the files from the CD-ROM onto the memory-stick.
Carry the memory-stick to the CD-lacking computer, and plug it in to a USB port, and install from there.
May 29, 2010 | Computers & Internet
It is the notepad version that has no disk drive, so how can I install a cam?
If your computer does not have a CD drive then -
There are two methods.
1. Purchase or borrow an USB external CD/DVD drive connect it to the notepad's USB port and install the software from this drive.
2. Use a different computer and copy the contents of the CD to an USB memory stick and then plug it into the notepad's USB port and install the software from this USB memory stick.
Mar 26, 2010 | Samsung NC10-14GW Notebook
What is the next version of Quick books Pro that will work with
Well I know the the 2008 version definitely works with Vista because I have it. So I guess the next version that works is 2009 or 2010?
Oct 15, 2009 | HP Computers & Internet
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Can i place a 4g and 2g stick in my macbook pro
Hello! The MacBook Pro you have mentioned can only support 4GB's total. 2GB's in the first slot, and 2GB's on the second slot.
What you may have seen by accident was that you can purchase either a 4GB kit, or a 2GB kit. Meaning a 4GB kit with 2 2GB sticks, or a 2GB kit with 2 1GB sticks.
Your best bet is to go with a 2GB stick in each slot to max out your MacBook Pro. 2GB's is the largest each slot can read.
For more information, check out the website below which has very detailed information on memory for various systems.
MacBook Pro Memory Information
Mar 16, 2009 | Apple MacBook Pro Notebook
Memory stick stuck
Some tape can help that! I had the same problem with a Memory Stick PRO Duo. You can see photos of the fix here:
http://lloydandlauren.com/2008/11/21/getting-a-memory-stick-pro-duo-out-of-an-acer-aspire-one
May 25, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
