Question about Zenith Televison & Video
HAVE A ZENITH MODEL Z56DC1D IT WAS MAKING NOISE FROM FAN SO I REPLACED FAN BUT STILL MAKE THE SAME NOISE WHEN YOU TURN ON T.V. WHAT COULD IT BE WHATS IT CALLED?
ALREADY CHANGE BULB HAS NO PROBLEM. BUT WHEN YOU TURN ON TV YOU GET A LOUD NOISE THOUGHT IT WAS FAN SO I REPLACED IT. STILL MAKES THE NOISE WHAT CAN IT BE AND WHAT IS IT CALLED?
  • 65 Answers
SOURCE: Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Posted on Dec 09, 2006
Slinteriors
  • 8617 Answers
SOURCE: My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Posted on Jul 22, 2008
  • 1030 Answers
SOURCE: I have a RCA 50in DLPModel #M50wh74s
Two possibiltes. A bad cooling fan or what is known as a color wheel. is this a whining sound. does the colors flicker. a bad fan could have contribited to the bulb going out too. to identify a technician would have to take back of and examine fans and listen
Posted on Dec 15, 2008
  • 152 Answers
SOURCE: my zenith z56dc1d will not turn on. I start the tv
sesshomaru69, Is your tv LCD or Plasma? How old iis it? Is it still covered by Warranty? Your symptom sounds like it could be a power supply problem internal to the set. You will need to have a service tech look at it. Probably the Switch-Mode-Power-Supply has sensed a failure with some other circuit or with itself and goes into what is known as SHUTDOWN mode to save itself from becoming a catastrophic failure. Your best shot will be to have someone look at it.
Zenith has a building somewhere in Lincolnshire, Illinois but they are owned by LG (Lucky Goldstar) Korea. Most likely everything in the tv is from the Far East and assembled in Mexico, but that's just a guess!!! I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Posted on Sep 17, 2009
Testimonial: "Fast and excellent service and very simply put. I thank you for being there with an answer that no one else could give. louie12fix is the best|"
ladywinn
  • 5138 Answers
SOURCE: 50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Posted on Apr 28, 2010
Zenith tv troubleshooting
Are you sure about the color wheel and the lamp? Make sure the lamp is Osram brand or it may not work.
Aug 29, 2014 | Zenith Z56DC1D 56" Television
I got a Zenith Z56DC1D the bulb was replaced and its clean. I have blurry picture and it seems out of alignment there is a large black stripe on bottom and the top of the picture is cut off. How do I fix...
Without seeing a photo it sounds like the picture is letterbox with top and bottom black areas---if not that it sounds like a possible issue with the optical light engine the set uses to project the image on to the screen----most of this is not customer repairable.
Dec 04, 2012 | Zenith Z56DC1D 56" Television
Tv does not turn on. Green light flashing!
The light flashing green is usually a start circuit issue---do you have the correct brand and model number listed here?
Nov 08, 2012 | Zenith TV Lamp 6912B22010A for Z52DC2D...
Zenith z56dc1d stays on standby mode after replacing dlp lamp
If problem is different from before lamp replaced remove the lamp and make sure the pins it engages on are not bent out of position--it is possible to insert the lamp and not get it in correctly.
If Zenith it was made for or by LG>
Jun 01, 2012 | Televison & Video
I need step by step instructions how to in stall lamp for my zenith z56dc1d
The steps are :-
1.
2.
3.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 12, 2011 | Zenith Z56DC1D 56" Television
The tv won't come on. the bottom red light flashes twice
YOUR tv does look like a dlp if it is ? then you need to start with lamp. if you replace lamp and clean vents and that don't help. then you need an electronic technition to determin whats causing your problem. J.D.W.
Jun 25, 2010 | Zenith Z56DC1D 56" Television
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
