Question about Coffee Makers & Espresso Machines
Our coffee tastes oily. Seems there's a grease or oil leak in our grinder. Is there a simple solution?
espressodoc
  • 29 Answers
SOURCE: saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
  • 2039 Answers
SOURCE: Coffee not strong enough
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Posted on Feb 09, 2008
ginko
  • 19396 Answers
SOURCE: Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 05, 2009
ginko
  • 19396 Answers
SOURCE: Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Posted on May 22, 2009
  • 352 Answers
SOURCE: Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
Why when grinder is on finest setting
Did you clean the grinder before using it? Did you run a 1/2 kilo or so of junk beans through to clean out any oil/grease that was in the system from manufacture? How old are the coffee beans? If you grind at a 4 and run it through the drip machine, does the coffee still taste off?
Apr 30, 2014 | Mahlkoenig K 30 ES Grinder
Grinder gets clogged after several uses
You should clean it with a brush After every use.
Feb 14, 2011 | Salton Coffee Makers & Espresso Machines
It keeps saying that it is out of beans even though its not. I think it is having trouble grinding...
This machine doesn't work well with oily beans. Most coffee beans you buy at the supermarket are quite old and stale with sticky, rancid oil on the outside of the beans. Even if you are buying Starbucks or Peets and the sign makes it appear that it is fresh roasted, if you read the fine print you will see that the beans were roasted up to 90 days ago.
You want freshly roasted beans that are not roasted so dark that they are shiny and oily. Don't buy Italian or French roast as these are too oily. Get a FC or FC+ roast or lighter.
To workaround, until you get some less oily beans, you can stir the beans up with a chopstick so that they work their way down into the grinder. You will probably have to stir before each coffee and maybe even stir twice to make one coffee.
If you have a hard time finding a local roaster where you can buy freshly roasted beans that you like, I've been having wonderful luck with RedBird espresso blend. It works perfectly with this machine and produces a delicious espresso. RedBird roasts daily and ships daily, the price was very reasonable and I recieve my coffee two days after they are roasted. The roast date is printed on the bag. Just fantastic tasting coffee.
The shipping cost is low and the price for 1 pound is great - but if you buy 5 pounds the deal ends up being even better. You can divide up into quarter or half pound batches in ziplocks (or mason jars) and freeze them and just take out what you will use each week.
http://redbirdcoffee.com/redbirdespresso.html
Good luck -- stir your beans for now and get yourself some fresh, non-oily coffee beans and you'll be grinding hassle free.
Oct 23, 2010 | Gaggia Titanium Espresso Machine
Grinder does not stop
I need more information to solve this.
If you mean the grinder just spins but doesn't seem to be grinding anything - and then after 30 seconds or so it tells you the bean hopper is empty - then the problem is sticky, oily beans that aren't sliding down into the grinder.
You want to buy freshly roasted (roasted less than a week ago) beans. Coffee beans from the supermarket are old, stale and sticky with rancid oil. Even Starbucks and Peets - although the sign says "roasted daily" if you read the fine print, the beans in the store are rotated out 90 days after roasting. The oils turn rancid and get sticky after a couple of weeks so you really need to get beans from a local roaster or order them from a roaster who ships them fresh.
I have been using RedBird espresso blend and these beans work perfectly with this machine. They also are the best tasting of any espresso blend I've ever tried. The price is reasonable (cheap even) and the roast date is written on the bag. I get my beans 2 days after they were roasted.
In the meantime, until you get some coffee beans that are not oily, you can stir the beans in the hopper. Use a wooden coffee stirring stick or a chopstick and just lift the hopper lid and stir the beans so they slide down into the grinder. You will probably have to do this before each coffee and maybe even 2-3 times just to get one coffee.
Once you get some fresh roasted beans that don't have that oily shine to them you will be grinding without any problems.
Oct 22, 2010 | Gaggia Titanium Espresso Machine
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
Coffee does not go from grind to brew basket. Plugs..must clean every time
Try running some unflavored panko breadcrumbs or rice through it. That will clean it up and remove any oil that's causing sticking. Try to use less oily coffee in the future to avoid this.
Feb 03, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
