Question about Hobart Dishwashers
Hobart dishwasher lxih ml130017 has code p2 and a wrench symbol I have replaced the final rinse thermistor 328994 and the p2 code and wrench symbol are still there.
This problem started after I used CLR to delime the vac breaker
3 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Hobart LXIH displays P2
The rinse thermistor is bad,look on the back of the machine to the right and you will see 2 black wires with a plug that screws into the vac breaker this is the probe.I bet when the dishwasher goes into the rinse cycle the temp jumps all over,let me know.
Posted on Jul 28, 2008
bigg t
  • 640 Answers
SOURCE: Hobart dishwasher rinse buket filling water
Can you be more specific please?
Posted on Mar 11, 2009
Trouble code P2
It seems that the rinse probe thermistor open or shorted.
Dec 30, 2015 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Sharper image ev-hd10
It's time to clean the insides with CLR or descaler or delimer.
Nov 28, 2013 | Humidifiers
I am not getting any moisture. The fan just runs but no water is being evaporated?
How old is it? it may be time for a descale. Do you have any CLR or a janitorial or restaurant or dairy quality delimer/descaler?
Nov 28, 2013 | Hunter CareFree Plus 33222 Humidifier
Is CLR safe on brushed nickel
Most descalers or delimers are tough on chrome/nickel. I believe the CLR formula does not attack chrome/nickel.
Nov 11, 2013 | Hansgrohe 27411823 Shower Arm With Flange...
There is a valve? leaking in the back, where can i find a new one?
If the valve is the round shaped one with two hoses going into it .that is the vacum breaker.Most likely a 3/4" you can get these at plumbing supply try just unscrewing the guts clean with delimer and unscrew the guts from the new one and screw them in.unplumbing the old vacum breaker can be tricky.the plastic fitting some times break.I use a 1/2" wire brush for plumbing to clean the vacum breaker houing.with delimer remember take your time and always back up your plumbing fittins with another wrench as not to put any stress anywhere else.
Apr 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
Mar 15, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Mar 11, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart AM15T ML-130039 with p2 message, what does this code mean
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
Jan 29, 2010 | Hobart 29 in. AM15-1 Free-Standing...
Dishwashers Logo
87 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
