Question about GE Tritonr XL GSD6260JCC Dishwasher
My GE Triton dishwasher won't drain. How do I de-clog it?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Posted on Apr 25, 2015
GE Triton dishwasher occasionally won't drain all the water..still in bottom of dishwasher or leaks into floor. Not every time!
make sure that a portion of the drain hose was hung higher than the connection to the garbage disposal. hose should not have kinks or twists. if that doesn't work, clean (no clog) or replace drain hose.
Oct 07, 2015 | GE Dishwashers
Ge triton xl not draining
You may have a clogged drain hose, or a bad reversing relay. Otherwise the "nut & plunger" (That's the thing at the back of your dishwasher under the filter in the back) is probably clogged or sticking.
Feb 20, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
I have a GE Triton XL Eterna Series dishwasher that is not draining. Can you help me diagnose the problem? Some people have told me that it is the pump, while others say it is the motor or drain hose.
Have you checked to see if there are food particles that might be obstructing the drain? Check the bottom center of the unit, there should be a filter, it might be clogged.
Feb 17, 2011 | GE Dishwashers
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Daniel
Jul 23, 2010 | GE Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Profile triton
Could be your pump and drain hose but first I would check the drain hose. There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Jul 11, 2009 | GE Dishwashers
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
GE Triton XL Dishwasher
It's normal for a little water not to drain. However, many times it's that the drain hose isn't looped up high enough under the sink and water is draining back from the sink or disposer drain- into the dishwasher. If there's a disposer, be sure to run it once in a while, a good time is when the dishwasher drains. The hot water and detergent keep the unit clean, and draining correctly.
Oct 24, 2017 | GE Tritonr XL GSD6260JCC Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
176 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
