Question about Cuisinart CMW-100 Microwave Oven
Runs when door is closed,stops when open!Checked the three door switches;all good.The mw is 5 years old so anyone have suggestions as i would be thanking U in advance
    Prodigy:
    An expert who has answered 500 questions.
  • Cuisinart Expert
  • 650 Answers
It is possible that a relay on the control board has stuck in the closed position. You can try tapping the relays on the main control board and this sometimes breaks them free. It still may be one of the door switches but I would suspect the control board or possibly a stuck start pad on the touch panel.
Posted on Apr 24, 2015
  • Linwood Tatum
    Linwood Tatum Apr 27, 2015
    IT's working. Thanks for the help.LT
  • Ty Roshdy Apr 28, 2015
    Glad to help. I have ran into this before.
  • Cuisinart Master
  • 17,130 Answers
There can be two chances that the MW works by itself when the door is closed. It can be due to a relay or the door leaf switches being jammed.
remove power and try to close and open door for several times.If this wont work, remove power and tap on the Printed circuit board and check again. If there is no result even after repeating this the fault is in the PCB wherein the output to the relay is short or there is a constant output to trigger the relay.
Need to check by tracing the output or replacing the PCB.- Try if you can swap.
Posted on Apr 30, 2015
    Top Expert:
  • Cuisinart Master
  • 10,875 Answers
Check door switch
Posted on Apr 28, 2015
WILL NOT SHUT OFF, LIGHTS UP, TURNTABLE RUNS, MAKES NOISE, ONLY WAY TO SHUT OFF IS TO PULL PLUG OR OPEN DOOR
This is a classic door switch problem. I fixed a friend's MW a few months ago that had this exact symptom. Got a family member's MW going again last summer for similar (not identical) problem.
In our case, one of the switches was broken (shorted). There are usually a group of similar door switches all mechanically ganged together behind the latch. If the MW has a wiring diagram, you can use it to figure out which switch controls the light, fan and turntable. Check the switch with ohm-meter after you get it out. The switch plunger may have lost it's springiness.
You need to be clever mechanically to figure out how to disassemble for the R&R (remove&replace). Don't break plastic mounting pin or you may have to improvise repair for that too!. It may help to have the service manual for your particular model (worth a google search). The switch is probably relatively inexpensive ($5 or so) and a generic replacement should work fine if it has the same-or-higher voltage and current rating.
Apr 22, 2016 | Microwave Ovens
MW runs when Door is opened and stops running when door is closed
It's almost certainly a defective door switch or switch mount.
My complete text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 15, 2011 | GE JVM1650 1000 Watts Microwave Oven
My fuse in my delonghi microwave keeps blowing
When a fuse continually blows on a microwave is due to one or more of the door switches to be defective,there is a minimum of 3 and as many as 5 door switchs, some of which should be normally opened, while others will be normally closed. That is built in redundency to assure that the door is closed when the m/w is on since i believe you do not want to be subject to radiation if the m/w could be run with the door open
Jul 23, 2011 | DeLonghi MW 535 Microwave Oven
GE microwave Model JVM1650SH01 innternal fan runs continuously
Check the door switches-I think you will find one or more either bad or not being contacted with the door latch.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
May 13, 2009 | GE JE2160 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Keeps running
interlock switches.. more than likely it is the monitor switch in the middle that needs to be replaced
Mar 17, 2009 | Microwave Ovens
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Panasonic microwave...
Without HV test equipment it is quite difficult to determine if it is the magnetron or inverter.
5 years is a little short for magnetron failure but it appears that this is about all you can expect these days from a magnetron - the best I have seen was 11 years. I have not seen an inverter failure as yet (although I am not a full time repair man). The main reason I suspect it is the magnetron is the short time period from start to stop - it is typical of magnetron failure in Panasonic microwaves.
As regards door hinge side, that is one of the great unknowns. I suspect it comes from most people being right handed but even refrigerators could be specified as right/left hand hinged originally and now can be changed by customers.
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave runs constantly
If it's less than a year old, it's under warranty and you should call the nearest Sears store for free repairs. Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www3.sears.com (the 3 is correct)
May 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Cuisinart CMW-100 Microwave Oven Logo
417 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
deton8 von Splosion
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
