Question about DeLonghi Heating & Cooling
Would you have thermostat for a Delonghi Model # EW7707CBC oil heater . Thank YOU
  • 45 Answers
SOURCE: Noise coming from DeLonghi TRD0715T Oil Filled Heater
seems to me you have a bad bearing in the fan. if you can access the fan, have a few drops of oil poured on the shaft of the fan and see if it solves your prob.
Posted on Jan 27, 2008
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Adjust Delonghi oil heater thermostat
you can't
Posted on Mar 01, 2009
  • 736 Answers
SOURCE: DeLonghi oil heater model HMW2400TG
one of three things are common causes of this problem ...most likely, dust builds up enough to block air flow then the unit will overheat inside .. that will trip a thermal breaker .. the breaker will reset when the unit cools .. if that problem continues then it may trip a permanent breaker .. if that happens the unit will stop working .. take the unit outside and blow the dust out of it with air pressure.. .. another common problem is if the fan bearings start to freeze then the fan wont run fast enough to maintain proper air flow .. lubricate the fan front and back bearings with light machine oil or sewing machine oil .. don't use WD40 or oil containing teflon .. the lube life is about 5 years so yours is way overdue for oiling the bearings if you haven't done so yet.. a third problem that is common is the electrical connections inside the heater are made with crimped on rivets .. the rivets loosen sometimes with age and a hot spot is created at the loose connection (you might even see sparks there) .. that can also trip the thermal breaker and is generally not repairable at reasonable cost ...
Posted on Aug 15, 2010
heatman101
  • 43501 Answers
SOURCE: oil is leaking from heater; heater is 3 yrs. old.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Posted on Jan 12, 2011
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Jan 23, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
57 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
