Question about Sanyo Televison & Video
I own a Sanyo dp46841 and after a recent lightning storm,I cannot get the tv to turn on. There is no standby light or anything. Got a New power supply board but it didn't help, any other suggestions??
  • 615 Answers
First check the power source to be sure the outlet you are using has power.
Posted on Jul 24, 2015
SOURCE: Sceptre power supply short circuit
I have the same problem. TV was JUST out of warranty. Sceptre part number is X37SV-Naga and the cost - $285.00 plus $20 shipping. Non-refundable, no returnable.
The TV is of course going to de-solder the board within a year again, so either a good heat sing on both thermistors is in order OR a law suit against Sceptre is in order for putting us a risk of fire.
Posted on Jul 09, 2008
budmrtn
  • 11361 Answers
SOURCE: My Sanyo DP32648 was plugged into a surge
If you look at the power supply board as shown in the picture: http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjdps153ap1a.jpg
There is a main fuse on the top left of the board covered by black shrink tubing, SLO-BLO 4A 250V. Check it out to see if it is blown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 27, 2010
SOURCE: Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Posted on Dec 24, 2010
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
gopakumarg43
  • 74136 Answers
SOURCE: Panasonic TH-50PX80U won't work after
Hello
If cable box converter has damaged, there is no question about the main board of your TV. It has been damaged. Before replacing it, you have to check the power supply board also. If the TV has been pluged to power supply, surely there will be fault to it also. We can't predict the exact fault occurs during a lightning, because Trillions of volts are passes nearby. You have connected the TV with cable connection and to the home power supply too.
Just replace the main board first. If it does not hel you, replace the power board too. I hereby send picture of both boards.
gopakumarg43_14.jpgThe first one is main board and the other is power supply regulator board.gopakumarg43_15.jpg
Posted on Aug 20, 2011
Model dp46841 sanyo 47 inch tv won't power up
Likely a power board issue. Check that capacitors are OK in the power board, and if blown then replace with exact parts. This is a $10 fix, but if it does not work after than then cost go up like replacing the power board completely.
Oct 06, 2014 | Sanyo DP46841 46 LCD TV 1920x1080, 60 Hz,...
My sanyo tv was hit by lighting I think it will not turn or have any sound
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Sep 20, 2014 | Sanyo Televison & Video
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
Sanyo DSs31820 dead after lightning storm. Is there a master reset?
A lightning storm will destroy a TV in many cases. I have repaired very few, with this problem. I would certainly find a new TV, if this is the case for sure. Thanks for asking!
Jul 11, 2010 | Sanyo DS31820 31" TV
Lightning
Power hits are very difficult to recover from primarily because odd things can happen. Usually the standby transformer or power supply takes the largest hit. With no symptoms to go on, it is difficult to provide a diagnosis remotely. If you have any electronics experience, start by looking for the standby 5V inside the set. If that does not exist, start with getting that portion to work. After that, hopefully the set will attempt to start and we can continue from there.
Dan
Sep 13, 2008 | Sanyo DS36930 36" TV
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Sanyo 21" t.v. will not power
I would check store and see if will take back, my not want to say it was storm. Just don't know first. If will not take back or exchange then open and look for open fuse, or open resistor in Power Supply.
Aug 22, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
89 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
