Question about WeatherWorks CH-748 Compact Heater
Need an owners manual
120V 60H
Can I connect Daewoo DVDP480 120v-60h on 230v outlet?
Not UNLESS the unit is equipped for that---if not you will toast the unit instantly.
Apr 22, 2012 | Daewoo Televison & Video
Have a Mitsubishi Big Screen, Model VS-5043 (AC 120V, 60H, 210W), and get no picture. I believe all I need are bulbs. Think it's worth a try to get them or should I have a repair guy get a look-see?
Hi dejjjavuu,
You have 50% chance that it is a bulb problem but you have a ballast board that supply the bulb also. The problem is, this board needs to check with an experienced technician for fault. But for me I've suspected also the bulb most especially if the unit is more than a year old, you can't test this bulb unless swap a new working bulb in the ballas board that's why you need to call an expert. However if you have a spare bulb you can swap it and try.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 09, 2011 | Mitsubishi VS-5043 50" Rear Projection...
We have s6000 generator and a 38 foot camper that runs on 30amp. Do we need to buy and adaptor and can we use the 30 amp plug on the generator. And do we use the 4 prong or three prong
You will probably have to buy an adaptor. Read the owners manual for the generator, the 4 prong should only be for 240V. The 3 prong should be 120V. But READ the owners manual. If it is this way you should be able to get an adaptor at your local hardware/electrical supplier or any RV store.
Jan 31, 2011 | Electronics - Others
No problem yet
http://www.impco.com.mx/manuales/master_cool/MC%20Moviles.pdf
Jul 11, 2010 | Mastercool Portable Air Conditioner
I can get the bake function to work on my Whirlpool 465 Self Cleaning oven it flashes numbers. The broil control works fine. What can I do to get the baking to work on my oven. It is digital the Model is...
You can check the lower igniter and see if it is glowing. If it is not glowing then check with a meter to see if it is reading over 120. If it is reading 120 or less then you need a new controler if it is reading over 120 then you will only need a new igniter. Hopes this works.
Jan 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Meyer mod # E-60H. Last year it seemed
You got the idea, because both the motor carbon
brushes and a weak battery is one of the major causes of your problem. So, have a check on these items.
Furthermore, also check the oil as well as the oil filter
if it needs to be replaced. When all the checks are done
and fixed, I'm sure that you will get the best result . Hope this will help you.
Oct 23, 2009 | Plumbing
Sound card problem Dell
download from this link
www.lostmydrivers.com/
select sound card driver
select creative
select your model name and model no
Jun 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
I need the owners manual for the Redi Smoke electric smoker .It is the Redi Smok by Burkhead Manufacturing Co. The model number is 09899. It has 120V AC-1250watts
I might have one if its the same redi smoke that was made in Houston Texas about twenty years ago or so...wimberman
Jun 12, 2009 | Old Smokey Grilling
WeatherWorks CH-748 Compact Heater Logo
61 people viewed this question
Top WeatherWorks Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a WeatherWorks Heating and Cooling Expert? Answer questions, earn points and help others
