Question about John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
  • Tom Witt
    Tom Witt Aug 29, 2016
    I just broke 3 new belts before I realized that the pulley that moves in to tighten the belt when engaging the lever was worn on the bottom. The lower half of the pulley was angled and the lower lip was almost gone. The belts would shred on the bottom edge before breaking. Once I replaced the pulley the belt tracked straight and all is well.
  • John Deere Master
  • 1,169 Answers
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Posted on Apr 24, 2015
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a belt diagram
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Thanks for choosing FixYa,
Kelly
Posted on May 04, 2011
rycgl
  • 1545 Answers
SOURCE: I need the deck belt
I fiound some beautiful pictures in a manual for the 48" mower deck by John Deere. I haven't
found the 42" diagrams yet, but I can TELL you how it goes on (or is supposed to). Loosen the sheaves (pulleys) and belt guides. The inside of beltl go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys. Good luck
Posted on Jun 18, 2011
SOURCE: How to change the Belt on a John Deere L130 with
why cant i get simple routeing diagram for the belt on john deere l130????
Posted on May 03, 2013
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
My rx75 runs well but will not engage the deck is it electronic?
The mower deck is 100% manually controlled with the yellow control handle. The linkage may be out of adjustment a lot, especially if new belts are now broken in. When engaged, the blade drive belt should be quite taunt,but not like a banjo string. Adjustment is easy and can be found on the operators manual.
Jun 18, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Replace mower deck belt
Take the old one off, measure it and round down to the next size which you can purchase from a dealer, online, or at a general small equipment supplier. There is no trick to getting it off and on, merely a tensioning pulley on a spring that you push on to create enough slack to get it off a pulley.
Oct 21, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
I am burning up deck belts on a 2 year old John Deere LA 105 mower
make sure the pulleys are free the check the arbor brakes
Apr 03, 2012 | John Deere Garden
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Garden Logo
888 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
