SG5 error code 9 will not sycn - Office Equipment & Supplies
  • 1 more comment
  • Brian Stavely
    Brian Stavely Apr 25, 2015
    SG5 is a sky caddie NOT a printer
  • ROD GANDY Apr 25, 2015
    www.ask.com/mfg.name/make/model/error_code_##/
    www.about.com/ or www.wikipedia.org/ or www.infolinks.com/ with the /mfg.name/make/model/error code ##'s and or what is it doing wrong.
Want to load new course tto my sg5 cannot find out how
I had the same problem with mine, so had to call Customer Services, ( you can find it on the internet ) and I asked for the course I wanted to download, and the guy did this for me there and then. Hope this helps you mate. ;-)
May 31, 2014 | SkyGolf SkyCaddie Handheld GPS Unit
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
I keep getting an error code when tryin to log into the internet on my playstation 3 . The code is 80028EA6
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn. Reconnect your power cable and flip the back swtich up again. Then make a new network connection.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Sony Playstation 3 (PS3) Console
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
k24674
