Question about Esprit Watches
I need a trusted Esprit watch repair shop. - Esprit Watches
How do i change the battery on a Jacque Leman 1215 watch?
There's a special 3 gear wrench usually only watch repair shops have it but if ur handy and know how to use a tape measure u can look one up and make one just don't use pliers or and hand tools or u will destroy the watch trust me I know
Sep 26, 2016 | The Watches
Manual for Freeze Watch FR020
Mike.
I looked pretty hard but I could find no manufacturer support or manual for this device. My best suggestion is to take it to a trusted jeweler or watch vendor or even repair shop to answer your particular questions.
Jan 02, 2015 | Watches
There were no directions with our Cote d' Azur watch. Where can we get any directions.
does your watch has a strap with N,E,S, W printed on it? Normally, it is located on the bottom side of your watch. If you tilt your watch, the direction will be pointed towards that direction. Consult Cote d\'Azur if you have that on your watch...
Dec 25, 2010 | Watches
How to set a date in a esprit chronograph watch?
how to change the day of a esprit chrono? i can change in first position the number of the day but not the name of the day turning clockwise in first position. anticlockwise doens't do nothing. what to do? in a cronotech how to change the hour of the chrono? i can put the arrow of seconds in 12 line, but the hour counter remain in position 10 hours. what to do?
Oct 04, 2010 | Watches
Needs battery. do we get one and put it in or have a specialty repair shop put one in?
Thank you for contacting FixYa.
You will need to find a local repair shop that can reseal after putting in new battery, or send to :
http://www.luminoxshop.com/luminox-repairs.html
Best regards. Jewel
Sep 08, 2010 | Luminox Navy SEAL Dive 3901 Wrist Watch
Stopwatch second hand stops/jams at 57 seconds point jamming the whole works. Watch stops. Keeps excellent time otherwise if stopwatch not used. 2003 ss model. Bought new from rolex.
This may sound obvious but it needs to be repaired by a jeweler/watch repair shop. Although it is possible that the stop watch second hand is out of sync it would usually mean that the stop watch is starting at 3 seconds before 00:00 for 57 stop. If that's the case you should be able to readjust the start/stop position by pulling the crown out to 1st or 2nd position and then pressing the stop watch start stop buttons. One press, one position. Although I am not certain of the exact sequence.
However if you are unsure or it starts at the 00:00 position you need to find a jeweler you can trust to do the work. Check out a few places and ask to see the credentials of the watch repair person then compare and make an informed decision. Don't just use the jeweler at purchase point.
Most times, if it's a simple repair, like readjusting the hands a good jeweler will do it for nothing.
Good luck
May 14, 2010 | Rolex Daytona 116520 Wrist Watch
Where do i get the instructions for my cote d azure watch so i can set it correctly
The only model I am familiar with sets by pulling out the crown and rotating the crown to set the time.
For an instruction book you would need to go through Esprit or find a store location that carries their product.
Company info and store locations can be found on their website.
esprit.com
Sep 19, 2009 | Watches
I am not able to change the day of week in my esprit watch ?
If you were able to change the day of the week by turning clockwise and now you cannot then it will probably need to be looked at by a repairer. Parts have either broken or become disengaged.
Jul 13, 2009 | Guess Collection Textured Dial Watch
MY Omega Speedmaster watch runs fast. How do I
Hi dgcgo. My advice, unless you're a watchmaker, is to take it to an authorised dealer or trusted watch repair shop, and get it done properly. The speed on automatic watches is adjusted by means of a tiny regulator, but the adjustments are minute and the watch is then usually bench-tested to make sure it is running ok. It's an expensive watch, so worth the effort, although if it's new, you can probably get it done under guarantee. Cheers; Eagle58
Jul 04, 2009 | Watches
Replacement of battery
i agree, luninox are fairy good water resistant watches and will need to be resealed properly...take to or send to a watch service you trust...dont take to a kiosk is all I have to say
Jun 27, 2008 | Luminox Watches
Watches Logo
123 people viewed this question
Top Esprit Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Esprit Watch Expert? Answer questions, earn points and help others
