No power fuse is not blown
I tested all diodes nothging looks blown tested flyback seems good continuity on all coils output transistor tests good what is bad?
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 24, 2015
I have a qsc 1300 and channel b wont switch on, its like the relay wont switch
it is not passing it's self test. check the usual suspects (shorted output transistors, blown mini fuse, and that annoying pcb mount fuse in the power supply (looks like a resistor with one stipe)) if they all check out, test the relay coil for continuity. if it is open then replace the relay, but if it reads below 200 ohms the relay is ok, and i'd bring it to the shop for more extensive testing and repair.
Mar 20, 2014 | QSC Audio Players & Recorders
793MB flyback went off.
bad power supply, a blown out transistor,diode, but check horizontal output first..
take it out, then test again,,if its stops ,and power light comes on,, then change h-output transistor.
Mar 05, 2014 | Samsung SyncMaster Computers & Internet
The picture wont come on, power is on but screen is black
this a lack of RASTER, TEST AND measure a) , fuse, c. breaker, transformer, filter, diode, rectifier, IC voltage regulator +horizonta output transistor, HV rectifier, and Flyback HV.
God bless you
Oct 11, 2012 | Mitsubishi WS-73907 TV
Samsung dlp hlr6167wx/xaa will not turn on
1) test the power supply for shot and open in the transformer+coil +filter+diode+rectifier+,fuse blown replace with the same capacity!+c.breaker tripped , reset.
2) test the HV horizontal output short or defective + Flyback short or defective Horizontal output +125Vdc+Vertical output +80Vdc+12Vdc colors+12vdc all other circuit for to CRT.
Remember the first thing do will have is RASTER.
God bless you. see the block.d
Aug 01, 2012 | Televison & Video
No power when television is turned on
1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
2) test the power cord for open or break
3) see for a blown fuse inside and replace, or c.breaker tripped reset.
4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
God bless you
Jul 31, 2012 | Zenith Televison & Video
Noisy left hand power output stage. Noisy transistor? No circuit diagram.
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
May 12, 2009 | Audio Players & Recorders
Problem
There is no "Flyback transformer" in the LCD monitor "Benq 17" model No. Q7T3". Such a component, a "Flyback transformer" is found in televisions and in Picture Tube type monitors. The red wire of a "Flyback transformer" is where 27,000 VOLTS comes out of to connect to the picture and such a voltage IS DEADLY so never enter a TV or computer monitor unless you know exactly what you're doing. To bring your hand too close to the "Flyback transformer" is to GET ZAPPED, you don't even have to TOUCH that transformer or the Red Wire that comes out of it!!!!
As far as a fuse blowing, NEVER PUT IN A FUSE WITH A HIGHER AMPERAGE RATING: it's there to protect certain components from being permanently damaged. If the fuse is blowing you must find out "why". There's got to be a short circuit in one or more components. Transistors, Diodes and Capacitors are easy to check for shorts. Transistors, Diodes are usually what short out. There's not much more I can say here.
A schematic diagram that shows the voltage on the many components of a running LCD circuit is what you need to find out where volatges should be. If a voltage is missing you must find out where the problem stems from. There are other ways to test circuitry, with an oscillascope and a schematic diagram that shows test points and the wave pattern that's suppose to be present.
May 31, 2008 | Computers & Internet
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
No hi voltage
using an ohmmeter' the B to C junction will test as a diode, but E to B junction will show low resistance, approximately 50 ohms in both directions. now, E to C ohmmeter test will test as a diode. the foregoing results indicate a good transistor. reading other than this indicate a bad H-output transistor. good luck!
Mar 01, 2007 | Emerson EWF2704 TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
