Question about Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire Carbon Monoxide Alarm
4 beeps with pauses for 2 year old carbon monoxide detector
Why is my 2 year old detector beeping 4 beeps with a pause and continue to do this? I had fire dept come check with no detection and the furnace repairman come in and we reset detector and it started beeping last night again after 4 day ago fire call
    Scholar:
    New Friend:
  • 93 Answers
I'm pretty sure that indicates an alarm. The pattern is referred to as "temporal 4" which is the alarm pattern for CO. Either your device is in a bad place or there is an intermittent CO leak which is exceeding the ppm (parts per million) threshold for a given time period. The instructions for the device will tell you what that number is. If you have more than one of these, I would try swapping them to determine if the problen is with the device or the location. Good luck!
Posted on Jun 14, 2015
4 Suggested Answers
  • 54 Answers
SOURCE: how to fix detector
You don't mention how old the detector is. If it is more than 5 years old the detector may be beeping to indicate the end of its service life. A smoke detector can last much longer but carbon monoxide detectors have a limited life span. If putting in new batteries doesn't fix the problem then most likely you will need to replace it.
Posted on Jun 10, 2010
SOURCE: my smoke/carbon monoxide detector keeps
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
Posted on Mar 29, 2011
  • 2374 Answers
SOURCE: I have a Kidde Carbon Monoxide Detector , How do I stop it from beeping every 25 - 30 seconds?
replace the battery? hopefully it is not actually reporting carbon monoxide.
Posted on Mar 11, 2015
How do we get the smoke & Fire detector to stop beeping, the cover is off and it is still beeping? There is no battery for these units.
Vacuum the sensor with a crevice tool and then the brush. If it continues, you need to replace it. Please do REPLACE it, smoke detectors saves lives.
The tendency is to leave batteries out or not replace fixed power units. All smoke detectors should be tested monthly and replaced every 10 years.
The was a family of three killed at the weekend in Brampton near where I live. They were in a rented house that had 'no working fire detectors'. That means they had them, but the batteries were dead or not installed.
https://www.thestar.com/news/gta/2017/02/22/no-smoke-alarms-in-brampton-house-fire-where-3-died.html
Feb 23, 2017 | Home
It was beeping every 15 seconds or so. I pulled unit off ceiling and checked batteries. Reinstalled. No more beeping. Do I need to replace batteries?
The beeping means that the detector was sensing low voltage from the battery. If the battery is over a year old, most manufacturers recommend yearly replacement on smoke detector batteries.
Dec 16, 2015 | System Sensor 2100rfadt Wireless Smoke...
I have two firex smoke and carbon dectectors, and 3 smoke detectors in bedrooms.
do they beep three times, pause then beep three times again? if so, they are going into alarm. since they all ring together, the only way to tell which one is causing the problem is to look for one where the leds are different than the others. If your detectors are more than 10 years old, replace them all as required by the national fire code (NFPA72). If they are only doing single chirps, that is usually an indication of a low battery...perhaps the breaker for the circuit has tripped causing them to run on battery only. good luck
Nov 27, 2015 | Kidde Firex 21007624 Ac Carbon Monoxide...
Two fire/smoke sectors occasionally beeping - no battery inside - connected to NetworX 1448E security system. We have changed the large battery in security - still beeping
If the units are more than 5 to 7 years old they have reached the end of life cycle and need to be replace. Smoke detector typically are only good for 5 to 10 years.
Sep 04, 2014 | Home Security
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Hi, I have two of your Nighthawk Carbon monoxide detectors, both under 2 years old purchased from Menards. about a month ago the one in the garage started beeping continuously saying it needed a...
Carbon monoxide detectors have a fixed life span. You did not post the model number and there is no way to tell how long it ago it or the parts in it, were made.
Mar 18, 2017 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
The detector has gone off two times within the last week. The detector reads "GAS" when it goes off. THe number the first time was 199 and yesterday is was 235. The first time I got out of the...
Propane is heavier than air so if the detector is mounted ABOVE the appliances that use it (or any tubing that brings the propane into the house) it (the propane) will NOT be detected, even if there is a leak. That said, the PRODUCTS OF COMBUSTION of a propane appliance will still contain carbon monoxide (CO) which is lighter than air and will be detected by a properly installed detector. If you continue to get alarms and readings that differ from each other, along with no error codes on the display, it sounds like the detector is really detecting something. If the fire department cannot identify a source, try calling the Kidde "Hotline" at 1-800-880-6788 and ask if they can recommend another agency in your area to check your premises. I don't think these units detect Radon but am not sure. If your dwelling is of relatively new construction, the problem can be complicated by the fact that there is less outside air infiltration to disperse any build-up of gas/radon/CO/etc. than is typical in older construction. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab
Dec 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector just has one sold beep and is not plugged in.
I assume you mean your carbon monoxide detector has one solid beep, and it is probably an AC unit. It may be safe to assume that it has battery backup if it is beeping without being plugged in.
First, you may replace the battery with a new one, plug it in and hit the reset button. If that doesn't work, you could bring it in to your local fire department to have it tested.
Check the expiry date on the Carbon Monoxide Detector. It should be replaced if it is more than 5 to 7 years old, check manufacturer recommendations.
A replacement carbon monoxide detector will give you the protection you need and peace of mind. Your safety depends on how fast you deal with this issue.
Jul 07, 2010 | Kidde Nighthawk Combo Gas/co Detector
Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire Carbon Monoxide Alarm Logo
702 people viewed this question
Top Kidde Home Experts
Paul Bade
Are you a Kidde Home Expert? Answer questions, earn points and help others
