Question about John Deere Garden
Why won't my Scotts brand John Deere L1742 start ?.
It just cranks and cranks. I have replaced the battery, air filter, fuel filter, fuel pump, and spark plug. It also has fresh gas in it. It worked last year fine. When I changed the fuel filter I noticed that the fuel line is bone dry after trying to start it several times. I check the line at the gas tank and its not clogged in the gas tank. When I go to start it, it turns over but won't start. I don't smell gas at all and it doesn't flood. Seems like it isn't getting gas to the engine. Any suggestions on what else I could do to get it started?
  • John Deere Master
  • 2,478 Answers
Check your fuel pump lines in right place
Posted on Apr 25, 2015
Testimonial: "You win the prize Denis!! I had the lines to the fuel pump switched But also, they sold me the wrong fuel filter and when I put the old one back in, it fired right up. Running like new!!"
  • Barry Rush
    Barry Rush Apr 27, 2015
    Thank you for your help Denis Key!!
    Top Expert:
  • John Deere Master
  • 45,407 Answers
I had the line from my tank collapse last summer think they are using too much ethonal in the blends and old hoses won't take it
  • 2 more comments
  • Barry Rush
    Barry Rush Apr 26, 2015
    How do you know the line collapsed? I mean does it look funny? As far as I can tell there is no gas getting into the line period
  • Eugene Rounds Apr 26, 2015
    Due to the length and routing lines can collapse at the bends blocking fuel fuel. Also some newer lines have liners that separate and collapse internally with no outward signs..Take a large syringe place the end of the line at the fuel filter and pull a vacuum to try pull fuel through the line. If this don't work try replacing the fuel line.
  • ray gallant Apr 26, 2015
    therein lies the problem we can not see the inside . I took mine off and tried to run a small rod thru it and no go . replaced and JOY behold that fixed it . runs perfect now
  • Barry Rush
    It wasn't that. I had the fuel lines switched on the fuel pump and they sold me the wrong fuel filter. Its working like new now. Thanks for all your help!!
    Top Expert:
  • John Deere Master
  • 10,875 Answers
Take the bowl off from the carb and make sure the float needle moves and that gas is running into the bowl
Posted on Apr 24, 2015
  • 2 more comments
  • Barry Rush
    Barry Rush Apr 25, 2015
    LIke I said the gas line was dry at the fuel filter so I no gas isn't getting into the carb. Thanks for your comment but do you have any other suggestions?
  •  johnny rebel
    johnny rebel Apr 25, 2015
    replace fuel filter,replace line from tank to filter,check for rust blockage in tank,replace all gas line,ethanol kills rubber,only use non ethanol gas in small motors
    like where can we find that gas with no ethanol in it seems all local to me has 10 percent anymore .
  •  johnny rebel
    johnny rebel Apr 26, 2015
    look near any boat marina,they all have non ethanol gas
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Scotts / John Deere 2554 will turn over but not start. The engine will turn over but once I turn the key to stop it will not turn over again until an hour or so passes. Either way it never starts. It is...
who made the engine ??? and sounds like you have multiple problems which should be addressed separatly. need more info on the cranking issue like new battery?
Nov 23, 2013 | Mtd Garden
John Deere will not start. fuel filter dry
some models have a fuel pump some are grivitey
May 03, 2012 | John Deere Garden
I have a John Deere Z820A 25 Horse Kawasaki. After about 45 minutes it acts like it is running out of gas. It will start again with the choke out, but won't run for long. I have replaced fuel...
I am an ex-z820a owner because these machines are terrible. Deere issued a PIP for these motors and maybe yours has not beed done yet. The best thing to do is get with a dealer see if the PIP has been completed then sell as fast as you can. I traded my z820a on a z920a and couldnt be happier.
Jul 26, 2011 | John Deere Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Feb 20, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
260 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
