Channel up button stuck.
I try pressing the TV/av button I get a picture then the screen goes black and it looks like when one is pressing the button constantly to surf the channels
  • Televison & ... Master
  • 2,045 Answers
If this is on your remote try to disassemble and clean it
Posted on Apr 24, 2015
No picture just av1
If the cat sat on the remote, it is likely it changed the tv to AV1. Just find the AV button on the remote and press it again and again. It should cycle through the different AV channels your TV has - my TV has 6 AVs, 2 HDMI and a PC channel so if yours is anything like mine, you may need to press several time to get back to your Sky/freesat/virgin box. Alternatively, some HDMI connected kit just needs turning off and on. That then sends a signal to the TV which changes the TV automatically. For example, my Blu-ray player does that.
Experience - I have a cat that sits on my remote and does the same thing!!
Jul 31, 2012 | Panasonic 37" VIERA Full HD 1080p IPS LED...
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
I have a Gold Star TV, several years old, that is stuck on a black screen with AV on it. I pushed the wrong numbers to change the channel and cannot get it to f\go back to tv mode. Can you help me?
If you have the remote, press the AV/TV button. If you have no button with AV/TV written next to it, look for a symbol that is the outline of a TV with a small + sign in the corner. Or, worse case simply press each button one by one, until you find the one that switches the channel. If you bring up something on screen you're not sure about, turn the TV off and back on again.
Jun 09, 2011 | Televison & Video
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
When i turn my toshiba regza on I cannot access DTV all I get is a black screen. when i press the menu setup button this comes on for about a second then goes off again to a black screen. I can still use...
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
TV stuck on blue video screen
This usually happens when you are on a source that doesn't have a signal such as a channel with no signal or an AV input that is not connected.
You should look for a button that has TV/VCR or TV/VIDEO on it. I've guessing that you've already tried to change the channel but if not try that.
Last ditch effort in that case may be to unplug the TV for a few secouds. Warning- this may wipe out any settings you have entered such as the channel programming (which channels to skip while surfing) but along with that goes the blue screen.
Jan 11, 2009 | RCA Universal Remote Control
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
