Question about Samsung 6150 Series 40" LED TV 1920x1080, 240 Hz, HDTV
What part do I need to fix my LED TV?
I have a solid black horizontal line going across the screen. I would like to know if replacing the main board fixes this problem or do I need another part.
    Top Expert:
  • Samsung Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 24, 2015
  • 774 Answers
Sounds like to me that someone hit the test button for the screen and the std test pattern has come on. This is odd unless someone hit the switch. Pray it's under warranty and get a new set otherwise.. it's not worth repairing.
Have samsung un55c9000zfxa led tv with horizontal lines across screen can it be fixed?
It's either the control board or the display itself.
You'll have to find a TV repair company. They won't be able to tell you for sure until they test it, and they may charge you to test it. The control board should be a cost effective fix, the display won't be.
Unless you're trained in Electronics, don't open up the unit and try to fix it yourself, there are hazardous voltages even when the TV is unplugged!
Jul 18, 2016 | Samsung Electronics UN55C9000 - 55in 9...
Horizontal line across tv
My VIZIO had that and after 250 .00 main board it works again .
Mar 21, 2016 | Samsung Televison & Video
Could my tv have a possible backlight inverter problem?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 29, 2016 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem...
Aug 06, 2011 | Televison & Video
Screen got black lines across it
Across vertically or horizontally... It makes all the dif. It could be 3 boards on the set. The YSUS-main the YBU-upper/YBL-Lower. The Y buffer upper controls the top half of the screen, the Y buffer lower the lower half and the YSUS-main controls those 2 boards. They work in unison, when one goes they all fail. The other possibility is dry solder joints on the the D, G, E, F boards. All you would need to do with that is reheat the solder joints at the ribbon cable conx.
Best Regards and Semper Fi
Aug 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Samsung 6150 Series 40" LED TV 1920x1080, 240 Hz, HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
