Question about Bissell ReadyClean PowerBrush Deep Cleaner
What's causing it to pour out to much solution
    Habit-Forming:
  • Bissell Expert
  • 159 Answers
Solution distribution problems are usually the filters. If you haven't been cleaning them after each use than now may be the time to clean them. There's one on the Water Tank Cap on the inside (looks like a screen) just remove it, clean and replace. The other is Under the Flow Indicator. Turn the Indicator cap and remove, lift rotor out the filter is under it, remove filter clean and reinstall in reverse order.
Posted on Jan 30, 2016
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Water pours out from underneath
Check your hoses inside the motor area. One may have come loose.
Jan 16, 2014 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
I have a swan steam generator model s14021 and its all working but when you press button to get steam water pours out!
Dont know the model ,but steam is water and if water pours out than the steam heat portion isnt getting hot . Probably a heating element out
Feb 17, 2011 | Vacuums
Water won't come out
Hi there SmartAlec from nelsonvacuums.com.au here. I think that the likely solution for the problem is that the water tank is slightly warped and so will not seal properly. Normally this is caused by using hot water in the tank. It should still be covered under warranty though just take it back to the dealer and get them to check it.
Aug 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have replaced the filters and the bag on my Sebo X1 automatic upright but it still has doggy odor that I cannot seem to get rid of. What could be the cause and what can I do?
Hi, Yeah those things are fairly simple and easy to clean, My guess is that its in the hose.
Try a weak solution of bleach and water, pour it in and let soak for 20 mins then rinse well. Dry it throughly in the sun before youe next use.
Jul 27, 2009 | Vacuums
Je nai pas de pression au bout de la brosse
Je suis désolé mais Fixya a seulement une version anglaise en ce moment. Cependant ce site vous permettra de copier et coller n'importe quelles réponses vous pouvez devoir votre problème pour que vous pouvez les lire en français. Vous pouvez taper aussi votre question sur ce site et cette copie et ce passé la traduction l'anglais sur Fixya pour une réponse plus rapide des experts.
Le site de traduction mentionné est un site de traduction libre. Juste être sûr de choisir les langues correctes pour la traduction à et de.. (L'anglais à français ou français à l'anglais) et utilise le bouton de Traduction LIBRE.
http://ets.freetranslation.com/
Merci pour utiliser de fixya. ..and j'espère que ceci aide ! ! !
Dec 22, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell ReadyClean PowerBrush Deep Cleaner Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
