Question about Vacuums
Why want brushes spin?
Already troubleshooted from manual
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Open the cover and check for a belt status.
Posted on Apr 24, 2015
Brush spins once then stops.
I don't know this machine but I'd check the bearings on the ends of the brush to see if they are spinning freely. If it has a drive belt try changing it, if it is an impeller drive check the vanes for damage.
By the way this machine I believe has a 5 year warrenty,
Jun 22, 2015 | Shark Navigator Deluxe Vacuum - Model NV42
How do I fix my vacuum the brush will not spin
Lubricate each end of the roller brush with motor oil. Bearings inside the roller brush need lubrication for the brush to turn easily. Remove any pieces of thread that have wrapped around the roller brush. If it does not spin after doing the above steps, then either the belt is slipping or the bearings are severely damaged in the roller brush. Then you need either a smaller belt or a new roller brush.
Apr 26, 2015 | Dirt Devil UD40270RM Quick Power Compact...
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
The spin bar under the vaccum is not spinning anymore.
Sorry to hear about the problem you're having with your DC07. Please note the brushbar will not rotate when the cleaner is standing in the upright position, or if you've used the brush control to turn it off.
To check the brush control is set to the correct position, please refer to the user manual supplied with your cleaner. In case you don't have yours to hand, here is an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have the cleaner reclined in the vacuuming position with the brush control set to 'ON', and the brushbar is still not turning, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting steps over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 23, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the red lint filter that is described in your troubleshooting for lost suction??
It is on the bottom, close to the spinning brushes. It is the red plastic pushed down into the input of the vacum turbine tunnel that utilizes the vacum from the water collection tank to spin the brushes. Make sure that the stem of the master brush is not broken off, after pulling up and out to remove the brush holding container.
Jan 29, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Lost manuel
Try removing the brush cartridge from the steamcleaner, and then put the end of a flat screwdriver into the square hole in which the cartridge connects to. Spin the screwdriver clockwise or counterclockwise if possible; if you can't, keep trying. Mine became jammed-up somehow, but doing this solved the problem and now the brushes spin again.
Nov 21, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
