Question about Refrigerators
I cant set tempature - Refrigerators
  • 773 Answers
Read the owner's manual. If you've lost it, download a new one from the mfr's site under "Support". If it's a model that is not listed, contact them via e-mail under "Contact." Follow the instructions precisely.
Posted on Apr 24, 2015
What should the room tempature and humidity be set on for a dehumidifier?
To what ever level your comfortable at. I let mine run in the basement all the time.
Sep 07, 2014 | Fedders Dehumidifiers
Where is ac/heater blower resisitor on 2003 acura tl located
Hey Dave, The resister is located on the left side of the blower motor on the passeger side. There are different applications of this part depending on model. Some models have driver & passenger or dual zone climate controls.This means there can be -2- different speed settings & tempature settings, & Then you have your normal where there is only -1- set of settings for the speed & tempature settings. Some are black or white in color ... Hope this helps
Jul 12, 2014 | 2003 Acura 3.2TL
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The tempature here in n.c. Was 98 today. Should the inside tempature keep up with the set tempature? It is set at 75 and inside will only go to 77. Is it broken?
a rule of thumb for this situation is 20 degress cooler inside you have that but it is still a good idea to have an a/c system serviced every year
Jun 17, 2010 | Heating & Cooling
A/C cant reach desired tempature
service the freon, Sounds like its low
Jun 13, 2010 | Heating & Cooling
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
I can not change the thermostat setting on the unit. Whenever I try to change it, it reverts back to the previous setting.
The thermostat will display the current tempature in the room. When you press the buttons to change the tempature and you see it change back it is probably going back to the room tempature display but still keeping the temp you set it at. Also make sure the "hold" feature is set or the temp you choose can change at different times during the day due to the programmable features built into the thermostat.
Sep 08, 2009 | Honeywell Heating & Cooling
Temputure and oil change
either you have a bad wiring prolem or you need new gadges
May 31, 2009 | 1997 Cadillac DeVille
TEMPATURE NUMBER SETTINGS
Buy a candy/fryer themometer. The setting numbers were inaccurate anyway.
Jan 11, 2009 | GE 168954 Deep Fryer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
