Question about Oase Garden
When I switch my oase pond vac on it switches off immediatly
  • 774 Answers
Sounds like a ground fault or polarity issue with the connection. Check your wiring with the circuit breaker 'Off" and verify it's "off" using an electrician's screwdriver. This will also tell you when you put the power "on" whether the polarity is correct.. red is positive, black is negative, and as always, Green wire is ground.
Posted on Apr 24, 2015
I've had a oase clear water filter for three years now with no problems. I was cleaning it at the weekend I notice water leaking out off the function switch I would appreciate any advice thanks Dave
It should you did seat down correctly, take out the filter and put back in. You might want to inspect the rubber around the filter for wear.
Apr 07, 2015 | Washing Machines
Oase helpline
www.lowes.com/cd_Remove+Algae+from+Your+Pool_13040116..
Jul 06, 2014 | Garden
Oase sp310g
Yes.Get the new impeller,take the unit apart,remove the impeller and put the new one on.Just do it.You never know tilya find out.Only way to find out is to just DO IT.
Apr 15, 2014 | Garden
Oase pondovac not working
I find that it sucks a lot more water if it's getting a little air from that valve thingy on the handle. Be sure it's tight and closed. I guess you could filter out the water through some media etc. using the hose attachent..into a large bucket with matting etc. and then set it up to go back to the pond. I'd go heavy on the matting though to be sure you're not just putting dirty bottom-of-the-pond water back in. I only use mine about once a month in the summer (bottom drain takes care of most waste), but am using it several times a week right now to get every speck before winter sets in. I don't do water changes once the filters are shut down, and I'm not feeding. I find the water stays clear and the water parameters upon testing are fine....all through winter.
Thanks
Apr 01, 2012 | Cars & Trucks
Hi got oase filter and everything just stopped working including the pump please could you give me some advice on what it could be thank you
It could be no power, bad wires, bad controller, bad switch, bad pump. You may have something as simple as a tripped Ground Fault Circuit Interupter (GFCI) breaker or receptacle. That is what I would check first. If you reset it and it trips as soon as you turn on the pump switch then you have a ground fault in the pump. I hope this helps.
Aug 30, 2011 | Oase BioTec 10.1 Filter
Pump runs and is fine on the output until i connect back to filter and there is not enough flow
Your filter may be clogged if not check for clogs in the fittings running between them. You will have some loss of pressure pressurizing the filter unit but it should not be a drastic loss.
Mar 30, 2011 | Oase Aquamax SF Pumps 3500 for Ponds ()
MY OASE PUMP SEEMS TO BE LOW ON POWER, IT PUMPS WATER BUT NOT ENOUGH TO GET TO THE FILTRATION TANK
Check to be sure that the impeller is not clogged in the center of the fins.
Sep 09, 2009 | Garden
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Aerate a pond
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
Dec 24, 2008 | Aquascape Designs Aquascape - AquaForce...
Garden Logo
207 people viewed this question
Top Oase Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Oase Garden Expert? Answer questions, earn points and help others
