Question about Boating
Is it a 2 stroke or 4 stroke engine? - Boating
  • Boating Master
  • 696 Answers
Hi Allen
An easy way to tell is look for an oil dipstick. If the motor has one, it's a four-stroke.
-Steve
Posted on May 20, 2015
I have a mariner Bigfoot 15 hp ser no OG 811362 it says on casing that it is 4 stroke but the guy I bought it from said it is 2 stroke how can I find this out with the use of she no
According to the ser #, your engine is 4 stroke. Does the engine have a dip stick to check oil level, a 2 stroke will not have this as it uses a fuel/oil mix. Also it will have an oil filter on 4 stroke. Hope this helps.
Jun 15, 2017 | HP Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
What is 4-stroking ?
it's how many rotations it takes to complete a combustion cycle.
2 stroke engines,4 stroke engines and Rotary engines.
May 11, 2014 | Poulan Garden
Do i put 2 stroke or 4 stroke in a 148cc engine
does the engine take oil? if it does then it is a 4 stroke and does not require mixed gas. if it doesn't have its own oil then it is a 2 stroke and requires mixed
Sep 25, 2013 | Briggs & Stratton Briggs Stratton...
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
Is the engine 2 stroke or 4 stroke
Honda engines are traditionally 4 stroke. If the exhaust comes out of the head it is a 4 stroke, if the exhaust comes out of the cylinder it is a two stroke.
Apr 16, 2011 | Honda XR 250 R Motorcycles
Self-propelled mower started smoking and it was running kinda rough. Then, it started smoking more and more while the motor slowed more and more with the increasing amount of smoking until it died. It will...
not if is a 4 stroke engine not being bothered to include engine make , model year etc makes answering accurately.
you could even say the color of the smoke
so here is a generic answer ( 4 stroke )
it indicates that there is a problem in the needle and seat and there is no fuel flow control in the carby
if it is a 2 stroke with a carby --same problem
ordinary engine oil (20w-40) for 4 stroke sump) and special 2 stroke for 2 stroke engine
Nov 16, 2017 | Poulan Pro 22" Self Propelled High Wheel...
Hi, on a poulan Titanium chain saw, what is the carb ajustment? Thanks Douglas Neil
Turn both jet screws CW to stops (lightly), then back both out 1-1/2 turns CCW each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on--the engine should 4-stroke. Adjust the H needle CW until the engine speeds up somewhat, but continues to 4-stroke. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carnt keep ryobi pcn 4545 running when i increse the power
How do you increase the power to an electric saw? By your question, I'm assuming a fueled engine model. Check the fuel filter, air filter, and muffler for any plugging. Check condition of fuel lines and tightness of carburetor fasteners. If no help, turn the H jet needle CCW about 1/4 turn--which should result in the engine 4-stroking. Will the engine now run at speed (but not as fast as before)? If ok, warm the engine up, open the throttle and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces best power and least heat! Hope this helps!
Apr 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Boating Logo
440 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
