Question about Garden
What is T/M oil and where is gauge or fill mark
I can't tell where my oil level should be? And what type oil?
  • 26 Answers
T/m is transmission oil. but need to know more info as to the make and model of the mower or trans axle.
Posted on May 11, 2015
Why is my oil pressure dropping?
first suggestion is to check the oil level in the sump as this indicates that on start up there is sufficient oil but when the oil galleys are full the pump is sucking air and the pressure drops to zero. The level has to be on the top most fill mark.
Apr 28, 2014 | 2003 Chevrolet S-10
I JUST BOUGHT A 2003 EXPLORER XLT [159,000 MILES ] ,MY OIL GAUGE AND BATTERY GAUGE STAY AT THE 1/2 WAY MARK WIYH ENGINE RUNING,DROPS BACK TO `0` WHEN I STOP THE ENGINE,BATTERY STAYS THE SAME ,WHEN I TURN...
All your gauges are working. The gas gauge Is also working. When you fill it, you will fill over the limit the fuel level switch will go by a couple of gallons. So the gauge will not drop for a few miles. until you use up the excess fuel
Aug 26, 2011 | 2003 Ford Explorer
For the pgo big max 50 cc they have the gear oil on thr left back side how are you supose to fill it ? Right when it goes to thr thread on the strew. I could find this answer in manuel
the bottom big bolt is the drain bolt.
the fill hole is a bolt which you take out to fill the fluid it is labeled with oil symbol or words. this is where you fill it.
there is another bolt you need to take out approx 1 1/2 inch above the botton, it should be labeled
fill or level but sometimes no marks, note: what your looking for is a bolt that dosen't attach anything, that bolt is specifically a level gauge bolt.
okay once drained, put the bottom drain bolt back in. and start filling in the top hole
until you see oil start coming out the fill/gauge hole, once you see oil start flowing out, put the bolt in and tighten, then put the top bolt in and your done.
dispose the old gear oil at your local auto parts store.
Best Regards
Big Al
May 22, 2011 | 2011 PGO Big Max 50
Where is the transmission dipstick in my manual 1.3 liter 1993 suzuki swift located and where do i fill it up?
LEVEL CHECK With Oil Level Gauge Fig. 1: Manual transaxle oil level check - with level gauge 84241046.gif
  1. Drive the vehicle to bring the transmission up to operating temperature.
  2. With the engine stopped, remove the oil level gauge front the side case of the transaxle.
  3. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  4. Wipe off oil level gauge with clean cloth.
  5. Fit the oil level gauge to the transaxle side case so that the threads rest on top of the case.
  6. Remove the gauge and check oil level. The level should be between FULL and LOW level line.
  7. If the level is below LOW mark, add oil until the proper level is reached.
With Oil Level/Filler Plug
  2. Raise and support the vehicle safely.
  3. Remove the transaxle oil level/filler plug.
  4. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  5. Transaxle oil level should be even with the bottom of the plug hole. If oil level is low, adjust oil level accordingly.
  6. Install transaxle oil level/filler plug and tighten to 40 ft. lbs. (54 Nm).
  7. Lower the vehicle.
Oct 17, 2010 | 1993 Suzuki Swift
How much oil to put in forks of my 1999 TE 610 Husqvarna?
You don't mention the type of your engine.But to make it easy for you to determine oil capacity, find the dipstick that gauge the oil level and you will see markings inch away from the tip.there is maximum and minimum level mark on it.
Sep 05, 2010 | 2000 Husqvarna TE 610
How do I add oil? Where is the oil fill located?
LOOK UNDER THE HOOD LOOK ON FRONT VALVE COVER THATS WHERE OIL FILL CAP LOCATED.YOU HAVE A OIL LEVEL DIP STICK BELOW THE FRONT VALVE COVER.LOOK ON THE OIL LEVEL DIP STICK WHEN ADDING OIL DONT OVER FILL THE FULL MARK LINE ON OIL DIP STICK THAT WHERE YOUR OIL LEVEL SHOULD BE DONT GO PASS THE FULL MARK.
Aug 12, 2010 | 2005 Chrysler Town & Country
Oil type for air compressor
You can go to any Home Depot and buy compressor oil for your compressor. Your operators manual should tell you what the level should be, however if you don't have one, filling it with oil until it fills the glass tube about half way should be sufficient.
May 16, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Cant find oil tank
most pedestrian mower engines do not have an oil tank,if it is a four stroke engine you will find a filler plu with level gauge either beside top of engine or near base,unscrew cap and fill to level on dipstick mark.
if it is a two stroke engine you will have to premix your fuel with a quality two stroke oil(most are either 25 parts fuel to 1 part oil or 50 parts fuel to 1 part oil(the fuel tank cap may have raised lettering telling you this),hope this is of help
Mar 24, 2009 | Garden
Oil level
Hi saturnin
That's the best way to get it right. Do what the manual tells you to do.
To check the oil
  1. Put the bike on level concrete on the center stand
  2. Check the oil with the dipper in the oil fill hole.
  3. Check it hot 10 mins after turning off the bike by unscrewing the oil fill plug, wipe the stick, and just dip it without screwing it back in, and check it for level.
  4. Pour in small amounts at a time to top it right up to the mark, but never ever over fill it.
  5. Screw back in the plug/dipper.
Hope this helps, am happy to answer any other questions you may have about it. Cheers!!
regards
robotek
Nov 15, 2008 | 2004 Kymco Venox 250
Oil level above full line
It's quite possible that when you fill the motor you are checking the oil level shortly thereafter, i.e. within 10 minutes, or you are filling the oil and checking what the level is BEFORE starting the motor (in this case the oil has not had chance to circulate and drain back in to the sump). Once the bike stands for an extended period (a couple of hours or overnight) you will find that the oil has drained from the head of the motor, and other places, back into the sump and therefore shows at a higher level in the sight gauge.
Nov 10, 2008 | 2003 Suzuki AN 650 Burgman
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
