Question about Dishwashers
Where can I buy a new glass for my laser dw 089?
    Top Expert:
  • Dishwashers Master
  • 34,711 Answers
Check with a local appliance parts supplier and/or the manufacturer/distributor for availability and source.
Posted on Apr 24, 2015
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Feb 10, 2015 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Dirty glasses dishwasher
1st thing is make sure the dishwasher is heating up the water.
if it is heating... you spray arms may be blocked up with food particals.
Mar 21, 2014 | Hotpoint Dishwashers
Dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
WHITE LINES
you need to clean the scan glass. If you lift up the cover where the faxes feed into the the machine and look towards the front where the faxes exit, you'll see a small strip of glass. This glass may be dirty or even have a smudge on it.ie: White-Out, toner, adhesive, etc. Just clean the glass with a cotton swab dipped in alcohol, let dry and you're problem should be fixed.
Jan 08, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Water will not drain
First, check for blockages.
Check the bottom of the washer for any broken glass, paper, plastic etc that can be blocking the drain.
Then check the hose and where it dumps into the homes main drain system.(Typically found under the sink attached to the garbage disposal or drain off the sink basin)
If the garbage disposal is bad or clogged, it can cause the DW to not drain as well.
If you have no blockages, then you likely have a bad pump.
If that's the case, check to see if the unit is under warranty.
If not, it is not uncommon for the cost of replacing a pump to approach the cost of buying a new washer. Especially if the washer is quite old or a near base model.
The parts alone typically cost 60 to 120 bucks. If you have to pay a tech to perform the labor, expect to pay between 175 to 275.
It is much easier to replace a DW than it is to replace the pump. So if you are unfortunate enough to have a bad pump, my advice would be to buy a new washer, and install it yourself.
I will be happy to help you with that as well.
(It's basically two hoses and three wires.)
Please don't forget to rate this solution.
Dec 26, 2008 | GE Nautilus 24" Built-in Dishwasher
Indesit idl 40 model, leaves dishes dirty and a dirty film on glasses.
First check if you are getting enough water into the DW, by opening the door after the fill cycle and see if you have about 1/4-1/2 inch of water by the edge of the tub. check that the water in the DW is hot (higher than 120 F) last, you may have a box of old DW detergent
Jul 20, 2008 | Indesit Dishwashers
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
It doesn't read any cd, it doesn't start reading any cd, do i have to buy a new one or i can fix it?
There is more solutions, if just doesn't read can be dust on laser reader of old firmware, if not running rotation and not blinking green light 2-3 sec and tryning to read CD you have to buy new one.
Sep 07, 2007 | Teac DW 28E CD-RW/DVD-ROM Burner
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
Owen Barnes
