Question about Dirt Devil BD10205 Express V6 Wet/Dry Handheld Vacuum Cleaner
Even though it has been charged it seems like it has no charge. Barely sucks for a few seconds and then dies.
  • 3,961 Answers
I'd say the rechargeable battery has died. They do have a life, especially the Ni-Cad type, and then will not retain a charge.
I don't know if that can be replaced in your unit, but if you can take it apart you may be able to replace the battery. Many types are sold on eBay.
Posted on Apr 24, 2015
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Honeywell 50150 stopped filtering the air
If you are recycling the filters then they could be totally plugged up.
Mar 03, 2014 | Honeywell Air Purifiers
Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
I have an air shark II and have no clue how to charge it ! there is a little wire that comes out of the controller and i plug it in and it just flashes red i let it charge for awhile and it still flashes...
The AirShark II has two ways to charge it. First you can plug in the USB cable into the chopper and then into your computer. The charging takes about 50 min. The second way is to take the little connector from the remote control and plug that into the chopper. The on button should be on the remote and the off button should be on the chopper. This also takes approx. 50 min.
Call us today for Virus Removal or other computer related issues
http://computech-ct.com
203-307-0452
Dec 15, 2012 | Cobra R/C 3 Channel Big Shark Helicopter
Quit working blinking light above settings knob
These things may not SEEM to move air, but they do - slowly and steadily purifying the air and adding a negative ion charge to the air which helps the dirt in the air fall down and be captured during vacuum cleaning, sweeping, etc.
Aug 08, 2009 | Sharper Image Professional Plus Ionic...
I can only get the low setting to work . I put a new card in and it did not help. could it be my fuse and where is the fuse located.
fuse is in back by power plug, but this unit sucks!!! i went thru 5 of them, the power supply keeps failing. they will rework it under warranty but it takes forever. call salesperson. good luck. I gave up on them and went to oreck. it sucks too, just plain unhappy cause the ecoquest ROCKS when working correctly, but the oreck barely does job
Jun 07, 2009 | Ecoquest Breeze AT Living Air Purifier
Sparks bluish bright purplish? very small sparks, after plugging in to wall socket. also rythmically every 3 seconds a cracking sound is heard concomittantly ..???!
Sounds like it needs a good cleaning. Does this one have the metal bars that pull out? I have a ionic pro and when it gets dirty it will emit small sparks where the dust connects from one bar to the other. It also has a pull up wand that cleans the wire that help build the charge. If this is the system that changes the charge on the ions to attract them to plates, you will see small sparks when it becomes dirty. Mine always let me know by the sparking sounds it makes.
Aug 02, 2008 | Bionaire BAP825-U Air Purifier
ALPINE AIR XL15
If that's one of those fanless air purifiers with parallel plates, it is not all right. The plates need to come up to charge and not discharge much at all unless there is a big contaminant particle (e.g. flying insects.) You may or may not be able to make the plates parallel again; there should be no sharp bits. If it's an ionizer, even then the flashing should be rare; otherwise you will get more ozone than you need. That can be fun, but it is not making plain old clean air....
Jun 23, 2008 | Alpine Air XL-15 Air Purifier
Can't turn it on -- need manual
you have to plug the unit into the wall directly and not to a power strip or UPS. Then just choose the speed for continuous filtering.
Aug 31, 2007 | Honeywell Enviracaire 17352 Air Purifier
Dirt Devil BD10205 Express V6 Wet/Dry Handheld Vacuum Cleaner Logo
334 people viewed this question
Top Dirt Devil Air Purifiers Experts
Vernon Taylor
Ross Stacey
Level 1 Expert
Tom Chichester
Are you a Dirt Devil Air Purifier Expert? Answer questions, earn points and help others
