Where can I get a plastic gear for the Staples SPL-TXC22A?
Staples Shredder SPL-TXC22A makes a "clunking" noise during use. Noise diminished after feeding a couple of WD-40 soaked paper towels but noise returned. Fixable?just use it until it dies and replace?
probably find that some cutters have been damaged and are hitting each other rather than sliding past each other
using wd 40 is lubricating those cutters but as the lubricant is used by the new paper it becomes inefficient
get a quote for repairs but generally ( unless the machine cost is in the 4 figure area) it is not cost effective to repair
Nov 28, 2016 | Staples Office Equipment & Supplies
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR WHEEL WERE TO GET PARTS
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Aug 22, 2010 | Staples SPL616X Cross-Cut Shredder
I need to replace the plastic guides in a Staples
did you ever figure out where to get these guides? i need them too. jeff
Jul 22, 2010 | Staples SPL616X Cross-Cut Shredder
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
226 people viewed this question
k24674
jasbo
jasbo
