Question about GE Refrigerators
Where are the coils on a GE model GSS25LGPA CC fridge ... Are they under the fridge or in the back?
  • GE Master
  • 5,323 Answers
If u simply look at the unit u can tell either its a condenser fan cooled or evaporator coil cooled the back will have a wired coil like cage or at the bottom it will have a fan condenseor unit see pics attched
Where are the coils on a GE model GSS25LGPA CC fri - 25663107-izj50bzy441rirqhwblyybfs-3-0.jpg
25663107-izj50bzy441rirqhwblyybfs-3-5.jpg Where are the coils on a GE model GSS25LGPA CC fri - 25663107-izj50bzy441rirqhwblyybfs-3-9.pngt/uploads/images/25663107-izj50bzy441rirqhwblyybfs-3-9.png" alt="25663107Where are the coils on a GE model GSS25LGPA CC fri - 25663107-izj50bzy441rirqhwblyybfs-3-20.jpgh_mi" />
Posted on May 12, 2015
2 Suggested Answers
  • 39 Answers
SOURCE: GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Posted on Dec 06, 2010
My ge frig side by side the frig side 65 degrees why need help model number tfx22zrxd
You probably have a defrost problem -accumulation of frost on the freezer back panel. check for frost first then ask additional questions.
if no frost exist, check the condenser motor under the fridge and also clean the coils.
Jul 07, 2015 | GE Refrigerators
HAVE A GE REFRIGERATOR TYPE TFX25CR THAT LEAKES WATER FROM TIME TO TIME, ABOUT 5 OZ
The evaperator for the drip under the bottom of the unit is probably dirty or has gone bad. Pull the fridge out and look under the bottom and you should see a pan with a coil above it. Clean the coil and the pan. If this does not correct the problem, then a new coil is in order. Also vacuum the back of the fridg if it has exposed coils to increase efficiency.
Dec 15, 2014 | GE Refrigerators
How to make me ge 29.8cu.ft. be more energy efficent. it is a older model.it is a profile tfh30pr. it seems it runs a lot.
If your fridge seems to be running a lot more than normal, it is likely because the heat dissipation coils are clogged with dust. Most likely they are located on the bottom of fridge.
There should be a removable kick plate under the door. Often just snaps in.
Remove kick plate and use a vacuum hose to vac out the dust bunnies.
At your local hardware store you should be able to buy cheaply a long skinny brush to reach between coils and clean out.
You should pull the whole fridge out and get it from back also.
This will increase the efficiency on your fridge.
If you notice no change at all, or if you've done this already, it's possible the fridge has a problem.
Nov 27, 2010 | GE Profile Performance 29.8 cu. ft....
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
Fridge and freezer not working
need more info, is compressor in back of fridge running ?
is the evap coil inside freezer froze up ?
is the fan inside freezer running ?
is the cond coil under back of fridge in need of cleaning ?
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Re GE TFX26ZP sid by side fridge Evaporator coil keep ice on it
the defrost thermostat should be clamped onto the evap coils..defrost timer should be under fridge. If this is a newer model, it might have an ecm ( comp control) on top of the compressor..
Sep 21, 2009 | GE GSL22JFR Side by Side Refrigerator
GE refrigerator works intermitently
change the thermostat my dads fridge did the same
Aug 11, 2009 | GE Refrigerators
Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
