Question about Garden
When cutting on a angle it shuts off - Garden
  • 1,909 Answers
Sounds like your float in the carb needs adjusting.
Posted on May 03, 2015
I am unable to cut 5" baseboard at 45 degree angle
from your last post this information was missing
when cutting at an angle the cut depth is always reduced and the 5" board is too thick
to do what you want the saw will have to be 10" or bigger because when cutting at an angle you are cutting a hypotenuse which is the longest dimension of a triangle
so if the saw cuts to a depth of 5" at right angles the angle cut will be longer because of the triangle effect
Nov 19, 2016 | Saws
Tip
Making a wooden picture frame with perfect corners
Picture frames are very easy to make, but many people make the same very basic mistake that will ruin your frame. It is very important that you follow the carpenters rule of measure twice and cut once. If you don't cut the sides of the frame to be the same length, and you cut the angles of the corners slightly off then when you put it together the final corner won't line up.
The things that you are going to need is a miter saw, some clamps, a backer board and a drafting squares to make sure you have the right angle.
To set up take your backer board and cut off a piece that's around 4 inches to be used as a sliding marker gauge. After cutting it off attach a small piece of wood to keep the slider from shifting around.
With the saw unplugged and turned off clamp the backer board to the back of the saw. To cut the corners of the a frame you need to set the saw to a 45 degree angle. Make sure to check the angle using a drafting square align one side with the backer board and bring down the saw blade align them to make sure its a 45 degree angle. When you think that its right grab yourself a piece of scrap wood and make an initial cut. After cutting the test measure the angle to make sure that it is the right angle.
When you are ready to cut the frame itself take the four pieces of the frame and make an initial cut. Once all the boards have been cut once take your slider marker to the length that you want the sides of the frame to be and clamp it in. Take the first two sides and one at a time line it up with the backer board with the angle on the outside and the cut point against the slider. Turn on the saw and cut the other end. Repeat these steps to cut the other three sides.
After all the sides have been cut use a 90 degree angle to align the corners of the frame. Lay out all the sides of the frame and line them up as tight as you can. To connect them you can use a staple gun to staple the corners together. If you were aligning it and pushing the sides together when you stapled the corners you should have perfectly aligned corners.
Now all that's left is to sand it down and get the inside ready for a picture and stain it if you want.
on Feb 17, 2014 | Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
The saw cuts at a angle, want cut stright2
replace the chain with a new one
saws that cut at an angle normally have blunt teeth on one side of the cut
the sharp side cuts the angle and the blunt side follows
Oct 23, 2015 | Garden
After using anew chaini hit dirt. isharpenit withadifferntanglewillthat make a differencein cutting.
sure will , most saws have different angle cuts to teeth on blade this "angle" needs to be maintained as the "rake" teeth that are behind the cut teeth are set to provide a good way to wipe out cut debris (cut,rake,cut,etc.) this is how chain cuts thru wood , if one changes the cut angle on teeth the rake teeth might not do there job correct and saw bogs and "files" thru wood rather than chips thru wood ,takes longer ,more fuel, more effort , a look at saw cuttings tells the tale , more tiny file sawdust = dull chain --- large Chips and less dust = sharp chain
Aug 26, 2015 | Garden
I have a 1985 fiero se v6 that was running fine but cutting off after warm up
Do you know what you are loosing when the engine stops running ?
Jan 16, 2014 | 1985 Pontiac Fiero
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
Unable to make a straight cut with saw. Tried adjusting tension, lowered blade, made sure blade aligned properly and did not feed too quickly. HEEEEEELLLLLLLLLLLPPPPPP! Thanks in advance.
Hello, I think that the problem you are having is called "drift" . each blade will cut different than the last. The way I was taught to cure this goes as follows.
-take fence off off table(or just move over)
-get a good square piece of material appx. 1x3 and mark a straight line about 1/2" from edge the full length of the board.
-with out the fence cut the board along the line appx. 1/2 the length.
-shut off saw WITH board in it.
-use a angle finder along the edge of the board, set angle finder
-remove board and put the fence back on.
-now slide the angle finder up to the fence, you should see that the angle is different than the fence (this is the DRIFT ), adjust the fence to the angle finder( I know that the smaller saws usalley don't have this adjustment ) you will have to find a way i.e. shim etc.
This is a very common problem but once you get the idea it is a easy fix
Remember: A guy taught me and I taught you, pass it along thats what we do.LOL
Hope it helped.
The Shop Dog
Oct 23, 2010 | Ryobi 9 in. Benchtop Band Saw
The car runs well until it gets hot ,it begins to loose power,then is stuter,then shut off. the car makes a coughing -like sound when it shuts off
could be your crank angle sensor to test .turn car on then let it warn up till it cuts out then tip cold water or hose for a couple of mins on the crank angle sensor then stop water and turn car on . if it buggard it will start as when the crank angle senors breaks or is on its way out it will start then idle for a bit then splutter run **** then stall with the cold water it instantly makes it cold again so it will start straight away and repeat the same process of stallin when warm
Sep 04, 2010 | 1995 Honda Civic
How do you tip the saw table to cut on an angle
Hi, usually there is a wheel or knob at the back side of the saw table , with a gage that will tip the blade for angle cuts
What make a model is your saw? I will search for details.
Please Vote !!
May 30, 2010 | Saws
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
