Question about Dishwashers
Why are dishes clean but still seem to be greasy?
    Master:
  • 456 Answers
Hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Posted on Apr 24, 2015
Samsung DMS300TR dishwasher. The dishwasher error code is F5, it switches off before the cycle is complete. The dishes ain't clean and it seems as if the dishes are still greasy.
Please see this page I found in the owner's manual for your machine. Error codes F1 to F8 (except F2) require you to unplug the power and turn off the water supply before requesting service, so this will require a professional service person.
Oct 01, 2015 | Samsung Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Greasy Film on dishes
You need to use something with citric acid in it like a can of frozen OJ or tang, the citric acid helps break up deposits. (run without any dishes in it) Hope it helps.
Mar 18, 2009 | Frigidaire Dishwashers
LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Jan 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Fisher and Paykel Dishwasher not getting dishes clean
Had the same problem and took out the inards and cleaned them. Also found that a lemon seed was blocking the drain channel - I used a piece of wire to snake it out. Seems like it needs periodic cleaning to keep it cleaning properly.
Nov 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
White film on glasswear.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Apr 01, 2008 | Dishwashers
Dishwasher spraying greasy spots all over pots & stuff after cleaning
Feb 25, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwashers Logo
172 people viewed this question
Top Dishwashers Experts
