Question about Lands Phones
6 incoming lines and 1 line has a dedicated message for employees to call into, this line is still ringing and I want to turn off the ringer on only this incoming line. How do I do this?
  • Lands Phones Master
  • 2,045 Answers
Refer to the stations' OM.
Posted on Apr 24, 2015
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
We have line 6 dedicated with a special voice mail and would like to turn the ringer off on that line only can this be done?
Ringing assignments are done by the system programmer. No you wont be able to shut it off by yourself.
Apr 23, 2015 | NEC Electra Elite 32D-1 Corded Phone
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Lands Phones
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Jun 15, 2012 | NorStar Meridian M7310 Phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
May 20, 2011 | NorStar M7310 Corded Phone
Landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Nov 02, 2009 | Lands Phones
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
Incoming Phone Ringer
After months of trying to solve this problem I finally figured out that the machine was set to phone/fax mode instead of fax only. If you have a dedicated fax line you can set to FAX ONLY MODE. In FAX ONLY MODE you can control whether or not the machine rings when it receives a fax call. You do this by selecting Data Registration, Press Set and use the up and down arrows to select 4. RX Settings. Press Set and use the up and down arrows to display the item you want to set or change and turn the ringer OFF. Press Set.
Mar 26, 2008 | Canon LaserClass 2050 Plain Paper Fax
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
