Question about Lands Phones
Is it possible to see incoming calls in a chronologic way even we got calling from the same telephone number in d600 model.We see that all callings from identical no are being collected one line Thank
  • Lands Phones Master
  • 2,045 Answers
That's the way how your registering dialer app works. Use a different dialer.
Posted on Apr 24, 2015
SOURCE: Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Posted on Oct 06, 2008
cnavarro
  • 2460 Answers
SOURCE: Caller ID display on Panasonic on KX-T7731 telephone set
Pick 2 buttons on the left side keystrip and label them CID-Indication and CID-Selection Then press PROGRAM press the button and dial 96 STORE for the first and 97 STORE for the second. When a call comes in, the Selection button will toggle between the name and the number and if yuu're looking at missed calls, the date and time of the call. When you miss a call, the Indication button will light and you press it to view the Names of missed calls.
Carl
Carl
Posted on Oct 24, 2008
  • 49 Answers
SOURCE: VTech model TM3111-2 the time
Assuming you are using T-Mobile@Home for your telephone service you should then;
type into your web browser address bar - 192.168.0.1
On the 'Setup' Tab with the sub category of basic setup look down towards the bottom of the screen for 'time setting.'
Click in the arrow for the drop down box and select your appropriate time zone.
Click on 'Save Settings' and you should be good after that.
Posted on Jan 07, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
Message light flashes continually; some incoming calls can't get through.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
As for incoming calls, are they possibly going to the aforementioned voicemail system?"
Jun 19, 2013 | Siemens Gigaset S455 Cordless Phone
Message light flashes all the time. Sometimes incoming calls won't work.
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Where are incoming call numbers stored?
Since you declined to specify the model of your Uniden DECT 6.0 phone, please select it from the list beginning here to download a copy of the manual.
Jan 14, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have a lucent Partner 18d telephone. I want to be able to have a button programmed so that the secretary can transfer incoming calls to outside phones ( call comes in, secretary presses a button, dials...
That is not possible on the Partner ACS. The oONLY thing that would be close to what you want is Remote Call Forward.
As long as you have a Partner ACS release 6 or higher,
You need to set the permissions on a phone, then set that phone to forward out to teh external number. Then when calls come in, you transfer to that phone, which will forward to a cell or external number....boom, done!
Thats it though.
Oct 14, 2010 | Avaya Corded Phone avaparp18d
How do I block an incoming call to my nokia 6230i phone
The best way to "block" a call is to turn off the ringer for that number on your telephone. Of course, to do that, that number will have to be in your contacts listing. You would not hear about the call wneh it comes in and you would of course, ignore it. Eventually, the caller will catch on and call using a different number and so it goes. Or, they may get tired of trying to harass you.
As far as I know, you cannot 'block' an incoming call as such. If it is possible, it will have to be because of the kindness of your service provider making the entry in their profile of your account in their software, if such thing exists. If there is law enforcement reason to do this, you may have more success. But at that point, you are probably better off getting a new telephone number.
Dec 26, 2009 | Nokia 6230i Cellular Phone
Call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
Jan 22, 2009 | NorStar M7310 Phone
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
Dec 16, 2008 | Samsung SGH-D600 Cellular Phone
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Lands Phones Logo
44 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
