After replacing the front load gasket the machine will not fill with water or wash.It just sound as if it is going to wash.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check water supplie
Posted on May 03, 2015
  • 1462 Answers
SOURCE: aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Posted on Mar 21, 2007
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
  • 188 Answers
SOURCE: Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Posted on Feb 19, 2009
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: How do I replace my door boot seal/door gasket on
There are 2 springs attaching the door boot. The springs are really tough but there are 2 separat tools for each spring. Use the tools to remove & install. It's tough but can be done.
Posted on Nov 10, 2009
Whirlpool Cabrio washer will not fill with water?
LF is a long fill the machine control has not detected a change in the contact of the pressure switch which controls water fill and stop you didn't mention top load or front load, on a top load or front make sure you have water going to machine if you have flood safe hoses to machine replace then with regular washing machine hose the design of these hose will stop water flow, crazy as this may sound make sure the drain hose has not fallen onto the floor water fills and runs right back out, as a tech I have not had a pressure switch go bad usually on a front load the clip that holds the black hose in place pops loose allowing the hose to rub against the rotor which turns and rub a hose in it sorry to be long winded two simple checks make sure you have water to machine and that the black hose from the pressure switch to the tub does not have a hole in it
Sep 01, 2014 | Whirlpool Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Apr 25, 2009 | Frigidaire GLTF1240A Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
