How do I get channels I can't get any time - Televison & Video
Well you can watch it online...There are plenty of websites out there which provide free streaming of nearly all types of channels...You can search online "the name of channel" with the word "live streaming"
Posted on Apr 24, 2015
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
What does it mean when a channel is "locked out"?
That is a setting that is used for channels that are constantly broadcasting but you don't want to scan them because they will stop the scanner. An example is the noaa weather channel. You may want to have it on the scanner as a channel but you don't want to scan it because the scanner will stop on it all the time.
Feb 25, 2015 | Uniden Bearcat 560xlt 560 Xlt 16ch Police...
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
How do i reset the lamp life for sony KDF-E42A10 ?
1) In standby mode, press the buttons on the Remote Commander sequentially, in rapid succession:
[Display] , Channel [5] , Sound Volume [+] , Power [ON]
2)To enter BE-micro service mode menu, press JUMP 2 times.
3) To display the lamp time, press Channel[4]
The screen displays:
“ Total lamp time is 14 hours”
4) To display the lamp time clear, press Channel[5]
7 times and Channel[1].
To reset the lamp time press Channel[3] > [MUTE] > [ENTER].
WRITE (Character color is red) is momentarily displayed and the lamp time is reset to “0”.
This worsk for other Somy retroprojection TVs as well, eg. KDF-E50A10 , KDF-E50A11 etc.
If you goto eserviceinfo.com you'll get the whole service manual
HTH!
zioanza
Dec 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
Do all 20 channels scann at the same time? S1&S2
I'm not sure which specific scanner you are asking about but typically they do not scan at the same time. The radio tunes (very Quickly) to each Channel (or Frequency), listens for activity and moves on. This happens very fast but not simultaneously.
elijam1
For all of your Scanner Needs ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Channel 2 goes fuzzy same time each day
This may be an issue with the broadcast. As all other channels are fine its not the tuner or TV. The broadcasters may be doing work on this channel at the same time every day.
I would advise contacting the people who broadcast TV in your area
Jul 15, 2009 | Televison & Video
Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
May 18, 2009 | Philips TP2784C TV
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
