Question about Hoover Washing Machines
Hoover hdb 642 n washer dryer - I can't start it! Followed manual but stop button continues to flash after selecting wash turning selector and then pressing start/pause button.
    Top Expert:
  • Hoover Master
  • 52,135 Answers
Can not read picture it's upside down .
Posted on Apr 24, 2015
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: indesit W1A111 starts cycle when selector set to "off"
hi i need a user manual for this machine. Where could i get one please. x
Posted on Jun 17, 2008
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
SOURCE: Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Posted on Aug 10, 2010
  • 662 Answers
SOURCE: My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Posted on Apr 21, 2013
Can I just use the dryer on Hoover hbd 642n
Yes you can. Page 24
http://service.hoover.co.uk/manuals/HDB%20642%20EN%2041032206.pdf
Oct 31, 2015 | Hoover Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Our Hoover Washer Dryer HW130M has stopped drying on the Tumble cycle. It continues to turn and dial turns to cmpletion but doesn't seem to heat up. Only realised as days cooler and not been using outside...
Yes could be the element but there is also a reset button for the element, designed to trip out if ever gets too hot. Remove the top of the machine and button should be clearly visible. Try this first before committing to a new element
Oct 05, 2009 | Hoover HW130M Front Load Washer / Dryer
Jul 27, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
185 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
