Question about Vacuums
Everything works but my brushes stopped turning. My son was using it and he said it just stopped. I smell something burning when i turn it on.
    Master:
  • Vacuums Master
  • 849 Answers
Hi, this is Jim with Crucial Vacuum,
Be sure to turn off your vacuum and unplug it immediately. There is a clog at the base of the vacuum that needs to be cleared before using your vacuum again.
Start off by manually rotating the brush roll. You want to be sure you can rotate without difficulty. This will also help unearth any hidden clogs behind it. If you notice anything wrapped around the brush roll as well such as hair remove this with a razor, or a scissor.
Your vacuums belt may have come dislodged when there is a sudden clog causing the brush roll to no longer rotate. You want to be sure the belt is on there nice and tight. If its not it could be causing your vacuums motor to overwork, hence the burning smell. On average you're going to want to replace your vacuums belt every 6 months, so regardless it may be time to change it.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 27, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,764 Answers
Looks like there's something which's got caught inside.
Posted on Apr 24, 2015
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
There's a burning smell when I plugged it in. I read the manual and it said I must plug into the grounded outlet. I have done so and am still scared that i am smelling the burnt smell
The grounding usually doesn't have anything to do with something cooking. If this is new, take it back for replacement. If it is out of warranty, check the bottom for a locked-up brush assembly/burning drive belt (motor trying to make the brush turn). If this is so, then remove the brush assembly, pull the end bearings off (note the orientation) and clean the ends of thread, hair, and other debris. Wipe the bearing ends and clean the outer bearing interiors with a 'Q-tip'. Replace the new belt in the same manner that the original came off. Check the air passages for any plugging. Try it to see if everything is operating properly and the brush is turning.
Aug 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Brush does not turn when vac touches floor
You need to change the belt. The belt will not turn the brush roll and is slipping on the drive shaft. This is creating the burning smell you describe.
You say you just brought it home.From where? From repair or is this a new machine.
Feb 03, 2008 | Vacuums
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
195 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
