Question about Toshiba Televison & Video
Help pls - toshiba 40bl702b Silent / No sound for a week!
Toshiba 40bl702b Cannot get any volume although reads thro numbers of increase on screen when press volume up /down. Tried manually with button on tv and via remote -neither works?
  • 13 Answers
Re: "Help pls - toshiba 40bl702b Silent / No sound for a week! Toshiba 40bl702b Cannot get any volume although reads thro numbers of increase on screen when press volume up /down. Tried manually with button on tv and via remote -neither works? "
Posted by kathleen on Apr 24, 2015
Solution:
This no sound fault occurs on Toshiba 40BL702B TV models and is easy to fix. After eliminating all obvious things like input connections etc, try this simple method.
Switch on the TV > Go to Menu (using button on remote control) > select 'Install & Re-tune' > click 'OK' > then select 'First time Installation' in the options.
After selecting country/region options allow TV to re-tune channels. When the set-up is complete, the TV should have reset and sound restored. Hope this works for you.
Posted on Nov 05, 2017
    Top Expert:
  • Toshiba Master
  • 74,384 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Apr 24, 2015
Toshiba 40BL702B lost table top stand screws
You can find the screws in your local hardware store.
Jan 17, 2014 | Toshiba Televison & Video
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Cheers!
Dec 27, 2013 | T-Mobile Concord
My 8350 was working fine now i cannot hear the phone ring and cannot hear text alerts
make sure the phone isn't on silent by checking the volume level.
Jul 24, 2011 | Blackberry Curve 8350i
No sound on my samsung galaxy s phone in need of help immediately please
Have you tried to increase volume by pressing volume up key? It will came out of silent mode.
Jun 15, 2011 | Cell Phones
I have a iphone 8GB and is on silent seen nd i don't know how to remove it on silent? pls can u tell me want to do?
To enable/disable the silent feature on an iPhone, simply look to the left-side of the phone. There will be 2 buttons there:
1. A small, switch that goes left/right. 2. A longer longer that can be pressed up/down.
Button #1 is the silent toggle switch. Moving it to the left enables silent-mode; to the right disables silent-mode.
Button #2 is the volume adjustment button which will raise the volume if pressed up and decrease the volume if pressed down.
Note: If you press the volume bottom down all the way, the handset will mute itself. When using the volume button, a volume indicator will appear on-screen to indicate how loud/quiet the phone is. If there are no white bars present on the indicator scale, then the iPhone is muted. Press up on the volume button a few times to increase the volume and disable mute.
Aug 11, 2010 | Cell Phones
My motofone f3 went into silent mode, even i increase the volume to 5 level the sound is not coming, after 5 if i press more it is going to vibration mode, could u please help me to get the ringing sound
YOU CAN TURN SILENT MODE OFF BY JUST PUSHING THE UP ARROW FROM THE CLOCK SCREEN AND HOLDING IT DOWN UNTIL IT RELEASES SILENT MODE. TO TURN SILENT ON JUST DO THE SAME PUSHING THE DOWN ARROW.
Jun 24, 2009 | Motorola Mobility MOTOFONE F3 + 10 Virgin...
My phone is on silent mode, how do i get it back to ring mode?
Go to your sound option under settings, and there should be an option for SOUND, you should be able to increase, the volume there, Let me know how it goes, thanks
Justin
Please Rate Me :)
Jan 16, 2009 | Nextel i836
Televison & Video Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
